Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-02-2005, 12:44 PM
frecca frecca is offline
'96 Rodeo Drivers Brake Light
Tail light unit is sealed. Can be taken off vehicle with four screws but access to bulbs seems to be from front of unit. How do you pop off the lens cover to replace braking bulb without damaging lens?
Old 04-02-2005, 01:45 PM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
Re: '96 Rodeo Drivers Brake Light
Access is from the rear of the tail light assembly. IIRC, you should be able to twist (~1/4 turn I think) and remove the bulb holder for which ever light you are attempting to replace.
2000 VW New Beetle TDI
2007 Honda CR-V
Old 04-02-2005, 02:14 PM
Re: Re: '96 Rodeo Drivers Brake Light
Thanks for your thoughts but there is no rear access (Typically, bulbs are removed as you mentioned but not this model . Access must be gained from popping off lens. Need to find out how to accomplish this without breaking lens.
Old 04-02-2005, 02:31 PM
Re: Re: Re: '96 Rodeo Drivers Brake Light
Did you try removing the two small screws on the back of the tail light assembly?
2007 Honda CR-V
