Old 04-02-2005, 11:30 AM
kennyrhit kennyrhit is offline
Send a message via AIM to kennyrhit
Swapping 3.4 for 3.1
I have a 99 3.4L alero. I too had the header/manifold gasket leak. Unfortuately I found out about it after it overheated and ruined my engine. So I have to replace it and I was wondering if anyone knew what mods I need to make to put in a 3.1 in its place. What do I need to change?
Old 04-02-2005, 01:57 PM
biv343 biv343 is offline
At a minimum, you'd have to replace the ECM and wiring harness - I don't think those are interchangable between a 3.4 and 3.1. The trans should bolt up without any problem, but I believe that the motor mounts are different also.
Might be better off finding a boneyard 3.4 and go that route - it will save you a lot of time and grief.
Old 04-04-2005, 12:21 AM
JTrujillo86 JTrujillo86 is offline
Re: Swapping 3.4 for 3.1
DO NOT GO TO THE 3.1L V6. I had that motor in my 1997 Malibu and it was a huge piece of crap. The 3.4's, athough similar to the 3.1's, are much more reliable than the 3.1's.
Jeremy
Old 04-06-2005, 10:39 PM
vamc's Avatar
vamc vamc is offline
FYI: a new 3.4L engine is about 2500-$3,000 for a new one. if you love it alot and want to keep it a long time, a new one might be the way to go, plus it will be under worrenty.
Old 04-14-2005, 12:07 PM
cficare68's Avatar
cficare68 cficare68 is offline
Re: Re: Swapping 3.4 for 3.1
Jeremy
3.4 are not that reliable either. I had one in a 1999 Grand AM GT and overall with in the 2 years of owning it i put well over $5,000 in repairs to mainly because everything dealing with the radiator went bad, the computer went bad, i would own another car with a 3.4 in it if my life depending on it
Old 04-14-2005, 04:42 PM
LeBuick's Avatar
LeBuick LeBuick is offline
Re: Re: Re: Swapping 3.4 for 3.1
Originally Posted by cficare68
3.4 are not that reliable either. I had one in a 1999 Grand AM GT and ... everything dealing with the radiator went bad, the computer went bad, i would own another car with a 3.4 in it if my life depending on it
But the motor ran well...
Old 04-15-2005, 07:20 PM
jamcllw jamcllw is offline
I think the 60 degree V6s from GM are probably some of the best engines they've ever built with the exception of the lower intake manifold gasket problems. I've personally owned 3 of them and each were around 250,000 miles when I sold them and they were still running strong.
