Old 04-02-2005, 10:51 AM
wranglermama wranglermama is offline
Unhappy Ford F250 Diesel Dies one minute after start
I have a 1999 Ford F250 Diesel that died yesterday with no warning, just shut off like I'd turned the key off. It will crank and idle for a minute, then die. I can even drive it for the minute it stays cranked. Is this a bad sensor? I would appreciate any input... Thanks! Wranglermama
Old 04-02-2005, 11:38 AM
BCMedic BCMedic is offline
Any codes, CEL?
Old 04-02-2005, 04:39 PM
ModMech's Avatar
ModMech ModMech is offline
Re: Ford F250 Diesel Dies one minute after start
Does the tach move while you are cranking it trying to start it (after it dies)? If not, replace the cam sensor.
Old 04-05-2005, 09:12 AM
w31770 w31770 is offline
Also check your fuel system for leaks on the suction side. Could be air in the fuel.
Old 01-07-2007, 10:02 PM
coreydon coreydon is offline
i had the same problem with my 03 f350 and it was the secondary fuel pump
