Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 04-02-2005, 10:45 AM
solchick solchick is offline
Quick Question about the Throttle Body
Does anyone know if there is some sort of screw or something that can be adjusted on the TB? My car is Idleing at 11-1200 rpms
thanks
2002 Nissan Sentra SE-R Spec V
91 Mitsubishi 3000gt VR4 Pearl White
Old 04-18-2005, 09:59 PM
slideways...'s Avatar
slideways... slideways... is offline
Re: Quick Question about the Throttle Body
i think every nissan has the idle adjust screw in the TB it should be a straight edge screw sunk into the TB probably facing up. different cars need different methods to adjust the idle speed so you wont just be able to turn the screw. iirc you have to unplug the throttle position sensor and do some other stuff then turn the screw then reset the ecu then plug the TPS back in or something.
also try adjusting the throttle cable. that may solve your problem.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
