Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-02-2005, 10:18 AM
Civic_D16Y5's Avatar
Civic_D16Y5 Civic_D16Y5 is offline
Send a message via AIM to Civic_D16Y5
engine squeak at higher rpms
in between 4500-6500 the engine may or may not make a sqeak or a chirp that i know is probalby not good, sometimes the squeak is like half a second, oher times itll just squeeeeeeek thru the rest of the rpm. what could this be?
also the quick squeek can happen during the decline of the rpms
http://www.carsponsorships.com/scout/sponsor.php?id=737
GET SPONSORED, QUICK
Old 04-02-2005, 11:30 AM
Brizow Brizow is offline
Re: engine squeak at higher rpms
Squeak or chirp? Hmm...may be a lose power steering belt, alternator belt, ect. Or it might be that you have a vacuum leak. My cold air used to squeak pretty bad cause I had a vacuum leak. Check to make sure your intake manifold nuts are secure. They tend to loosen up and that would also cause a squeal or chirp. Just some ideas it may be something else. Hope you get it figured out.
Old 04-02-2005, 12:45 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
sounds like a belt
Team Lonely Drivers
