Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 04-02-2005, 09:13 AM
tmande tmande is offline
2004 Grand Cherokee Failure to Start
I have a 2004 Grand Cherokee Limited, last week as I was leaving work, I put my key in the ignition and the engine failed to turn. It made no attempt to turn over what so ever. This is the second time I have had this problem, neither time was there any indication leading up to the car not starting. On both occasions the dealers have replaced the starter. I am certain that was not the problem. I had this problem with a 99 Grand Cherokee in the past and when the toe truck arrived the driver said it was a glitch in the security system. He knew just how to reset it and I was able to start the car and drive home. Has anyone else had this problem? Thanks, Terry
Old 04-02-2005, 10:48 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: 2004 Grand Cherokee Failure to Start
Try placing the transmission in NEUTRAL and see if it starts.
Old 04-06-2005, 09:35 PM
jason kolacinski jason kolacinski is offline
Im having the same problem with my 95 grand cherokee. I can turn it to where the radio comes on, the antenna goes up, that position on my ignition works fine. When i go to start it nothing happens at all. it doesnt even make a sound. It first did it about a week ago and it started fine after the about 3 times of trying. Now it doesnt want to do anything. If you find out what is wrong with yours please reply back.
Thanks
Old 04-06-2005, 10:42 PM
if you get the same thing after putting the tranny shifter in NEUTRAL, Check for voltage at the Starter Solenoid while having somewhere turn the key to start the jeep. If you get VOLTAGE the the STARTER is bad. If NO VOLTAGE then the Ignition Switch is most likely the problem.
NOTE: the NSS could be the problem but ussually will operate in NEUTRAL.
