brake pedal is hard-no brakes-help
my brake pedal is hard and I have almost no brakes-it happenned all of a sudden, a couple months after replacing the front brakes. I have no loss of brake fluid and have taken off all the tires and all of the brakes look fine. any help would be appreciated.
Re: brake pedal is hard-no brakes-help
Could be a couple of things. Most likely a bad master cylinder or a crimped brake like or a frozen caliper. Good Luck.
John |
thanks...the master cylinder seems to be fine as i can still hear it operating when i turn on the key. I also tried replacing the brake pressure accumulator today, and that didn't help anything. I am going to take a look at the front calipers today. could it maybe have something to do with the power brake booster? if so, how can i replace it and where is it located? If there are any other ideas please let me know but thanks for the help.
Before you check anything else. I was just thinking. Have you looked at the brake booster vacuum hose?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
that is what i was looking into also, could you maybe give me any help as to how i can locate this power brake booster or hose? my haynes manual says it is somewhere on the firewall, but i don't know exactly where. i appreciate the help.
What year is it and which engine?
it is a 1990 with a 3800 engine
If you replaced the accumulator, then you do not have a vacuum assisted breaking system. You have the electro-mechanical Teves system. Did you replace it with a new one?
By this description Quote:
yes I replaced the accumulator with new----I think your correct---I do-not see a power brake booster-the master cylinder is bolted directly to the firewall with lots of components connected to it.
EH I'm really intrigued by this electric booster...was not aware of that. Can you make a short story about it so it can make my day and in what years that contraption was applied ?
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. |
Here's a good write-up of the Teves system for the T-brids. It's operation is very similar to those found in the GM cars. The Teves system is found on the 89-90 SSE, Reatta, and some other GM cars in that era.
http://www.albeedigital.com/supercou...bs-system.html Last edited by randman1; 04-03-2005 at 04:59 PM. |
I have replaced both front calipers,the accumulater,and the relay and still the pedal is hard-I also took off both rear tires and the cylinders are working fine---I can hear the pump run and it does pressure up the accumulater---I checked all the fuses and have found a page similar to your posting about the teves system-----I am baffeled! Could I need the whole new master cylinder assembly???Maybe I just need some gas and a few wooden matches.
You are now beyond what I know about this unconventional braking system. I've included another link that might help. I have heard that the master cylinder/pump assembly is over a grand from gm. I once saw one on Ebay for $20 that the seller had laying around for years. That was about 4 months ago though.
Reatta site: http://www.reatta.net/brakes/brakes_...eshooting.html |
