Old 04-02-2005, 06:02 AM
loeschj loeschj is offline
Send a message via AIM to loeschj
94 S-10 Blazer Starting/Power Problem
ok heres whats happening with my S-10 Blazer 4.3L 4x4...when my truck sits there for about a day i open the door and the lights are dim...i go to turn the ignition over and it cant get enough power to do it smoothly, it's kinda like the starter is sticking and cant go but i dunno thats why im here...once it does turn over and usually it does the engine revs really high for a second then goes to normal then the interior lights are bright like normal...i have just replaced the fuel pump and filter about 3 days ago...i have changed the battery, and the starter a few months ago and i got them and the alternator tested at checker and they said it was fine...i'm stumped on this and so is everyone else that i've talked to...i had some issues with once i changed my spark plugs about 5 months ago that my cruise control, vents and 4 wheel didn't work...i looked forever to figure it out and i couldn't but then i say a vacum line by the distrib cap and connected it now all 3 work fine but i'm still having the starting problems with it and am getting very irritated, its like theres a power drain somewhere when the trucks off and i cant think of anything so please help me!!!!
ty
Old 04-02-2005, 06:20 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: 94 S-10 Blazer Starting/Power Problem
I would say the alternator...Testing isn't always reliable... Also the tester itself isn't always reliable... It's either that or you have a draw in the system that is draining the battery and making the battery too weak to turn the starter.,.
Old 04-02-2005, 06:23 AM
Officer Redneck's Avatar
Officer Redneck Officer Redneck is offline
Send a message via MSN to Officer Redneck
Howdy, welcome to the forum. Before any of the real gurus ask, are your battery cables clean? If not, it could cause the problem you are having. Get a battery post cleaning tool and make sure the cables and posts are good and clean then see what happens. Good luck.
2003 Honda Element EX
2002 Kia Spectra (can't "Improve" or wife will kill me)
1986 Dodge Ramcharger (For sale with a 1966 Rambler 660 classic to boot)
" Idon't know how many of them it would've taken to whoop my ass, but I knew how many they were gonna use. Thats a handy little piece of information to have right there." "Ron White"
http://www.myspace.com/officer_redneck
Old 04-02-2005, 06:51 AM
i've cleaned the terminals, the connector and everything for the battery, i'm still stumped on what it could be...is there anyway to test it somehow to figure out where there could be a draw in the system
i know that there's been a problem with my rear defrost...its not hooked up in the back and the switch is kinda funky...it seems that once i got it fixed and hooked up this problem happened...could it possibly be the switch...
Old 04-02-2005, 10:42 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
It is the alternator for sure, it might not be completely dead, but it is weak.
The engine is overrevving because the engine notices the low alternator output and is adjust ing the idle to get the voltage up to par.
Replace the alternator soon or you will kill you battery again.
Make sure you charge you battery back up before you install it with the new alternator.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 04-06-2005, 01:04 AM
still not working
i just changed my alternator and it is still having the problem...any one else know what it may be?
Old 04-06-2005, 01:32 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
could be the voltage regulator
Old 04-06-2005, 01:47 AM
anyway to test that?
Old 04-06-2005, 11:47 AM
im not sure, go to autozone and ask them they should know
