Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '01-'05 Civic
Old 04-02-2005, 03:43 AM
85civ15s 85civ15s is offline
how to remove an 05 ex-se coupe head unit/rca converter install?
does the ex-se coupe have rca outputs stock? i dont think so but im not sure, if not how do i remove the head unit to install a converter? pics? instructions? can i install the coverter in the trunk? all comments welcome. thank you
Old 04-02-2005, 08:04 AM
BrodyP's Avatar
BrodyP BrodyP is offline
AF -Advisor
Re: how to remove an 05 ex-se coupe head unit/rca converter install?
Here are 2 threads that will assist you, one being a DIY and the other being a general discussion on your topic.
04 DIY same for 05
General discussion 05
03.IS300.MT.LSD. 'Supra in Training'
Old 04-25-2005, 03:15 PM
btemple296 btemple296 is offline
Re: Re: how to remove an 05 ex-se coupe head unit/rca converter install?
The link to the DIY thread is broken and I tried to search the forum for this and was not able to. This is exactly what I am searching for, how to remove the head unit from my 2005 Civic, I hope the thread hasn't been deleted/removed. - brent (I'm new to this forum)
04 DIY same for 05
Old 04-25-2005, 03:20 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
you can install the converter in your trunk. You just need to splice the speaker wires to the converter and your done.
Empty Pockets Racing Member #1
Old 04-25-2005, 03:41 PM
How would I splice in to the speaker lines?
My end goal will be to connect my iPOD via one of the kits that connect to the CD Changer circuit of the factory head unit. Did Honda run CD Changer wires to the trunk?
Thanks
Old 04-25-2005, 03:50 PM
GScivic7's Avatar
okay, i think i'm a bit confused on exactly what you're using. Do you have a link or anything to the converter that you are trying to install?
Old 04-25-2005, 11:39 PM
if you have an SE there is an Aux port right on the front, i an unsure if there are wires running to the trunk but it seems to me that it wouldnt matter to you because you would then have your i pod in your trunk. am i misunderstanding this? oh, and i did splice the speaker wires in the trunk on the pass. side right out of the loom before they split to different speakers, works great!
Old 04-25-2005, 11:56 PM
GScivic7's Avatar
oh hell, it's two different people no wonder i was so confused.
Old 04-26-2005, 07:41 AM
Sorry,
Yes I am a different person that orginal poster. I don't have an SE or a head unit with a built in AUX port. If I could splice in the trunk, that is certainly an option, but I am not sure of functionality.
Here is one device that connects to factory head unit and you can control iPOD play list as if it is a CD changer:
http://www.crutchfield.com/S-dl0UmYf...o&i=581PA10HON
There are a few of these with simular features. There are also devices that just connect to head unit and give you RCA jacks w/o the custom iPOD connector, so it would work with any MP3 player, DVD, Sat Radio, Etc. I am not sure what sort of device I would need if splicing into the speaker wires in the trunk and how I would control my iPOD and also supply power to it.
I have ordered the $4.99 instructions from Crutchfield on how to remove the factory head unit, it comes with a bonus item called "Crutchfield Guide iPod Car Installation Guide", so I will see what that is all about when it arrives.
I am thinking for my purpose, I will need to remove the factory Head Unit. I had the front center console apart and found 2 screws below the power adapter, after I removed them, it didn't seem to free anything up. So I put everything back together assuming there must be some other way.
Sorry to be so wordy, just trying to "clear" things up, but I fear I have made it more muddy in the process of explaining where I am in the process.
Thanks
Brent
Old 04-26-2005, 09:18 AM
BrodyP's Avatar
AF -Advisor
Strange those links did work, one still does
http://www.7thgencivic.com/forums/sh...d.php?t=153830
http://www.7thgencivic.com/forums/sh...center+console
Old 04-26-2005, 10:11 AM
I just found a DIY and the console looks just like mine (2005) it indicates 2004, but everything looks the same. It is a shame, I was right there, just didn't have the guts to put a little pressure to the head unit.
http://www.7thgencivic.com/forums/sh...d.php?t=176750. Now all I have to gain from Crutchfield is the IPOD booklet, which I think I arleady know my options! :-)
Thanks for this awesome forum.
Brent
Old 05-04-2005, 05:55 PM
CUScoot CUScoot is offline
Send a message via AIM to CUScoot
Ok let me see if i got this correct. The rca converter will give you a place to plug your rca cables to your stock head unit and run them to your amp. Am I correct on this point. And where can I find one of these if this is actually what it does.
Old 05-04-2005, 06:01 PM
GScivic7's Avatar
Yup that's what they do. Best ones on the market for the best price are found at www.davidnavone.com
Old 05-04-2005, 06:04 PM
BrodyP's Avatar
AF -Advisor
Your answer
Old 05-04-2005, 06:55 PM
Thanks for the help.
