Old 04-01-2005, 11:29 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
Q. about OBD0-OBD1
I have a map sensor on my Tb, do I need to do anything with it? I didn't see anything for it on my conversion harness or stocker.
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 04-02-2005, 04:29 AM
GTA's Avatar
GTA GTA is offline
Whee..
Re: Q. about OBD0-OBD1
your stock map sensor plug will plug into it. so unplug from it on the firewall and plug that plug into the one on the throttle body.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 04-02-2005, 06:09 AM
Scott82 Scott82 is offline
i had to lengthen my wires for it to reach the TB, it's under the little black box on the passanger firewall
Old 04-02-2005, 06:45 AM
aight thanks
Old 04-02-2005, 01:20 PM
GTA's Avatar
GTA GTA is offline
Whee..
i didnt have to lengthen mine, i think i just pulled out a few clips that hold the harness for it down and it reached.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 04-02-2005, 10:03 PM
even better sweet, time to go get her running
Old 04-02-2005, 10:40 PM
Just got mine runnin, havn't got to drive it yet but it sounds good. Hope you have the same luck. One thing, don't wrap up your dizzy wiring until you get it started cause of the two white wires that you can't tell the difference between. You'll know you got it backwards if one there is no spark and two the dizzy gets warm to the touch just from turning over the motor.
Old 04-03-2005, 11:41 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: Re: Q. about OBD0-OBD1
Also isnt there an 02 sensor wire that can be switched also? unless your not running a 4 wire.
I cant remember, I converted a buddys car to 0BD1 acouples weeks ago, I cant remember....
2002 Acura TL Type S
1991 Honda Crx Si
Old 04-03-2005, 12:19 PM
yeah I was wondering about those two wires... so the vaccum lines for the old map and purge seliond do i need thos any more, as i can't find anywhere to hook em up.
and my started crapped out on me, so I gotta go pick up a new one of those. It does nothing at all, even when I'm jumping it, and the lil plug and the plug under the rubber boot that you don't have to disconnect read 9 volts on the meter all the time!?
Old 04-03-2005, 04:41 PM
i just capped off those vac lines and tucked them away, i wasn't sure if it would mess w/ any other vac components so i just left them and hid them from sight.
