Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-31-2002, 07:54 PM
Bendiak_BMW Bendiak_BMW is offline
Post 17" or 18" for BMW 325is
I have a 1994 325is which I would like to get a set of summer performance tires/rims for. I live in Calgary, Alberta, Canada so I will definitely keep the original 15" rims with true winter tires for winter use only.
What are the recommended sizes of tires for these rims?
Could you go through a list of pros and cons of the 17" vs 18"?
One concern I have about the 18" is the possible damage due to potholes etc.
Old 04-01-2002, 10:30 AM
Luke@tirerack Luke@tirerack is offline
you will have a very tough time finding an 18" wheel and tire combination that does not require a fender lip modification and an alignment hange so I would suggest that you stay away from that size. Using a 17" or a 16" would be preferable. Also these are the tire sizes to use 205/55-16 or 215/45-17 to avoid any problems. I would go with 17's for the improved steering response, handling and visual impact.
Luke Pavlick
Objects in the mirror appear ... to be losing !!!
Old 02-08-2003, 11:20 PM
op012503's Avatar
op012503 op012503 is offline
Send a message via AIM to op012503
Hi!
You said you own a 94' 335is; how has she been treating you. I ask because i've been looking for a used car or a while and I think that the 325is is the car for me.
thanks
Old 02-28-2003, 07:49 AM
MidNiteMysT MidNiteMysT is offline
i want to get 17's myself. i own a 1995 honda prelude si, i heard that 215/40/17 would be the best size but im scared of potholes, i heard there are going to be alot after this winter. i also plan to lower my car. would 215/45/17 be too much or could i even go any bigger?
