Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 04-01-2005, 10:57 PM
SCREIST SCREIST is offline
1992 Maxima battery discharging
An interesting electrical trouble. I've spent a few hours trying to find the source of a load that is draining the battery. About 50% of the time when I shut the car off there remains about a 3amp load which will completely drain the battery within about 24 hours. I have removed every fuse & relay one at a time & oddly the circuit draining the battery does not come after a fuse. Hmmmmm. Does that make any sense? The other 50% of the time when I shut off the car it's fine, a 0.3 amp battery drain remains. (probably just the clock or radio memory etc)
The battery is only about 1 year old & checks out ok.
Could this trouble be related to some of the grounding troubles I read about?
Thanks for any ideas.
Old 04-02-2005, 02:11 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: 1992 Maxima battery discharging
Originally Posted by SCREIST
An interesting electrical trouble. I've spent a few hours trying to find the source of a load that is draining the battery. About 50% of the time when I shut the car off there remains about a 3amp load which will completely drain the battery within about 24 hours. ....
Only way is to continue hunting with schema. Check out www.autozone.com ; free login, some schemas are there... Look for another link on my homepage1, bottom.
Could be alt voltage regulator. If I remember right, its got fuse in the blk box beside batt. Needs new alt: get original or one with lifetime warranty, remans will blow...
Dont think groundings cause this. Bad =missing gnd does blow the alt regulator. rRrepair...
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
