Old 04-01-2005, 07:45 PM
persuazion persuazion is offline
Do the 99 LeSabres have PCV valves??
I heard you should replace them but I cant find it on my engine for anything.....
Old 04-01-2005, 11:36 PM
s426 s426 is offline
hi
i`m speaking for 97 .if you are facing the car.its located on left edge of engine plastic cover intake manifold. it has wire plug and set on two way black threaded plastic nut. take the wire off then twist the plastic base .its inside,
Old 04-01-2005, 11:41 PM
Re: Do the 99 LeSabres have PCV valves??
ok...Im going to check..thanks
Old 04-02-2005, 10:10 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Re: Do the 99 LeSabres have PCV valves??
Same location on the '99 3800 V6. When servicing or changing PCV don't forget the o ring seal during re-assembly.
Old 04-02-2005, 03:35 PM
I still cant find the damn thing...is it under the plastic cover??The only thing I see to the left of the cover is the belts and some metal tubing going in front of the radiator..
Old 04-02-2005, 04:32 PM
BNaylor's Avatar
The pcv valve is located underneath the MAP sensor located on the passenger side of the intake manifold right next to the alternator.
First you have to remove the MAP sensor. Undo electrical connector. Push in on two plastic clips and pull off. Then take a socket or open end wrench and twist on what appears to be a plastic nut. Either to the left or right 1/4 to 1/2 turn. Remove this part and right underneath is the PCV valve. Take needle nose pliers and remove PCV valve by pulling up.
Put in new and assembly is the reverse. Don't forget the o ring, etc.
Good luck!
Old 04-04-2005, 04:38 AM
i`ll tak a picture tommorow for you ,if you wanna wait.
Old 04-04-2005, 10:30 AM
Re: Re: Re: Do the 99 LeSabres have PCV valves??
http://xs.to/xs.php?h=xs23&d=05141&f=P1010013-1.JPG
http://xs23.xs.to/pics/05141/P1010012-1.JPG
Old 04-04-2005, 06:41 PM
Re: Re: Re: Re: Do the 99 LeSabres have PCV valves??
ohhhhhhhhhhhhh...ok I got it...thank yall for the help...thats one more part I can mark off my" Where the hell is it" list....
