Go Back   Automotive Forums Car Chat > Audi > A4 | S4 | RS4 | A5 > '94 - '01
Old 04-01-2005, 07:41 PM
importaudihaus importaudihaus is offline
what does chipping actually do?
does it just raise boost? adjust fuel? or does it let the computer use the boost without throwing a cel? cant i get just the same results from a fpr and a mbc?
Old 06-17-2005, 10:52 AM
str8whippin str8whippin is offline
Send a message via AIM to str8whippin
Re: what does chipping actually do?
it makes the turbo run higher boost, it also raises the redline and makes your engine have more power by reajusting it to the setting the chip wants.
Old 06-18-2005, 04:19 AM
mikeho mikeho is offline
How Performance Chip Works
A year ago I asked the same question about how the performance chip works. So I asked this question to a guy named Ron Price from PES-Tuning, and here is his answer:
The GIAC ECU Chip for your Audi achieves its 50-55hp gain by raising
the turbos boost pressure from 8 pounds to 16 pounds, plus allowing
increases in timing and fuel delivery. The chip is soldered into your cars ecu replacing the stock chip. The only time a check engine light would
appear is if an engine malfunction had occured, the chip alone will not cause a cel. The tiptronic chip will work in any format with or without an aftermarket ecu chip. Thanks
Ron Price
Technical Sales Associate
PES, LLC
www.pes-tuning.com <http://www.pes-tuning.com>
267-288-0161
