Installed new starter and it's making noise...
I replaced the starter the old one was shot. I've tried to realign the starter about 5 times but once the engine starts it sounds like the starter is still running. Anybody have any clues on what I might try? I tightened the top bolt first then the bottom one I inspected the the way the face plate lines up with the starter and it appears to be straight. Help???
Re: Installed new starter and it's making noise...
I had this problem with my starter on my explorer. they gave me the wrong starter. they gave me a starter for an automatic and mines a manuel and the starter was not disengaging. Sometimes u can make a starter fit by putting a washerbetween the starter and the starter housing to space it. But the first thing i would do is pull the starter and just eyeball it and look to see if when the starter is not engaged if it would not be touching the flywheel
Re: Re: Installed new starter and it's making noise...
Wait did u say u have a manual and they brought out the starter for the automatic and it was the same as yours but the one for the manuel was different?
Yes I have a manual transmission and when they (Advance Auto) looked up the part for a manual tranny and brought it out it was different the bolt pattern did not match up. When they brought out the one for the automatic tranny the pattern was correct. I still have the problem I've tried to shim the starter and it wtill sounds like it's enganged with the flywheel after I start it. I think the new starter/solenoid is bad. I also replaced the ignition swithch incase it was shorted and coausing the problem.
I was pretty sure there were two silinoids one on the starter and then the 93s have one on the left inside fender. (passenger side). If i recal i wa shabving starting issues and i bought a new silinoid and it never disengaged my starter and blew my original one up, so that could be it. goodluck
I believe what your talking about is the starter relay. I checked the voltage going to the solenoid and in the start position I had 12 vdc. When I let the key go it dropped to 0vdc which lets me think the starter I bought has a problem.
