more power for my vic
Hi, I have had my 92 crown vic LX 4.6 L. for 6 months now, and I am very supprised at its poewr and performance. But I was dissapointed when I raced my friends 93 Buick Lasabre Custom, and he beat me by like a 3/4 a car length. I'm not saying that racing is right, in any way. But anyways, how would I upgrade my engine? For more poewr and faster acceleration, and even better gas milage? I have heard of these p71 chips and such. Please help. Thanks.
![]() Car details: Year: 1992 Make: Ford Model: Crown Victoria LX Liters: 4.6L Horsepower: 230hp? |
Re: more power for my vic
dual exhaust, better MAF and airbox (from a Marauder), and a chip fromwww.blueovalchips.com or www.sct-flash.com same technology (the BEST for Ford vehicles) but different sources.
ok.cool . So any chip from that website will work on my car? Will it be as easy that I will be able oto do it? Because I have no experiece with cars. And if It is hard, who do I turn to? Also, where do I look to buy my dual exaust for my vic? I have no clue where to start
Any salvage yard will have dual exhaust from a police car, town car, or one with the towing package that will simply replace your single exhaust. Aside from that, an exhaust shop can do this as well. It is not difficult, nor should it be expensive (over $300).
Installing a chip is fairly easy, once you get the coating off of the ship port on the computer (VERY easy to remove and clean). |
Ok cool. Thank you for yourhelp Mod. I am ganna start modding when I get my paycheck
. I think I will start out with the Switch Chip from the fist website that you gave me, and then Ill put in the Catalys Converter (Whever its called) and then the dual exhaust. Thanks again for your hewlp
If your gonna spend the $$$ to go dual exhaust,you should'nt just throw in stock mufflers and be done with it,the stock muffler(s) are very restrictive.You need something with some flow to really improve your engines performance.I recommend Flowmaster's 30 Series Mufflers,I have Dual 30's on my '87 Vic,and it easily gave me a 20+hp boost.If you have limited mechanical skills,the MAF and Airbox from a Marauder will be the easiest install for you,allthough it will not give you the performance of a Cold Air Intake.On my '87 Vic I custom fabricated a Cold Air Intake out of 3in. pipe so thats in runs into the front fenderwell just in front of the tire,I then put a K&N Cone Air Filter on it,and Installed a 80mm Throttle Body.It took me about 3 hours to Fabricate and Install everything,and it gave me about a 25-30hp Gain.Also Installing a Raidiator with Electric Fans,removing your mechanical fan and installing performance pulleys,will free up about 15-20hp and give you about 3-4mpg more than your getting now.These are some of the easiest things you can do to make more Power,but I could go on and on.
So far you claim to have "gained" 20hp on mufflers, and 25-30 Hp with this CAI/K&N/TB set up. Since you started with about 180 at the crank you should be in the neighborhood of 220-230 based on you "guestimates", and I would wager you don't have 180 at the wheels right now. As you can tell, people who post their ideas without data to back it up irratates me. Lots of claims, no proof. I have dynoed dozens of crown vics, Town Cars, Marauders etc., NONE will gain anything close to what you claim with the mods you listed. Especially an early 90's CV with small valves, low-lift cams, and a restrictive intake and Catalyst system. |
Re: Re: more power for my vic
hehe ok thanks guys
. Iwill try everything. The cats, the exhaust (Normal, not the Flowmaster or such things), Switch Chip, and also.I have one more question. What is Forced Induction? Can I do that with my car? Cuz with forced induction with the chip,. it is like 50-75HP gain it says. that would be awsome. thanks guys
Re: Re: Re: more power for my vic
You claim to have "gained" roughly 45 HP from your mods, not gonna happen pal. Even the '87 GTs did not produce the gains you claim, with more mods than you made. You upper intake is crap for good airflow, most knowledgeable people with the 5.slow use the "GT40" upper and heads to get the numbers you claim from CAI, fan delete, and UDs. Get real. Quote:
Just so you know, most of the Marauders (highest output panthers ever to leave the factory) typically dyno about 245-250 RWHP, so you should be able to spank every Marauder ever produced in stock trim. He will never get there without forced induction (blower, turbo etc). Quote:
