Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 04-01-2005, 05:48 PM
myk60099 myk60099 is offline
Passlock Anti-Theft Problem
Is anyone else having a problem with their Impala, causing you to have to wait about 10 minutes to start your car. If so what fix is needed for this?
Old 04-02-2005, 03:02 PM
Pat_OD's Avatar
Pat_OD Pat_OD is offline
Re: Passlock Anti-Theft Problem
were you in an area that was cold when u tried to start your car? Sometimes the temp will mess with it. My girlfriend had the same problem, she has a 2004 saturn ion and she told the dealer and they replaced it for free. Have you tried a dealer yet?
Old 04-02-2005, 03:48 PM
it has happened both in cold and warm temperatures.. usually on the average of like 1 time a month, which isn't horrible, but still annoying as hell when it happens. I was told by a couple of people it was some sort of short in one of the ignition components, but not quite sure which one.Then once the computer resets after like 10 minutes, it starts just fine....
Old 04-03-2005, 09:15 AM
Pat_OD's Avatar
yea check out the saturn forums they may have a solution i know saturns seem to have a big problem with it.
Old 04-05-2005, 08:33 PM
micali micali is offline
it sounds like the ignition. I have the same problem with my 01. kinda expensive.
Old 04-05-2005, 08:47 PM
Re: Re: Passlock Anti-Theft Problem
I've got some good info from a guy on this forum. When he emails me back I will let you know. This si the removal procedure for the ignition
REMOVAL PROCEDURE
Disconnect the battery ground (negative) cable.
Remove the steering column filler panel.
Remove the knee bolster bracket.
Remove the instrument panel (IP) cluster trim plate bezel.
Remove the ignition switch bolts. IMPORTANT: The Passlock(TM) electrical connector cannot be removed until the lock cylinder is removed.
Lower the ignition switch away from the instrument carrier. Insert the key into the ignition lock cylinder. Turn the key to the run position. Depress the detent on the bottom of the ignition switch housing in order to release the ignition lock cylinder. Remove the ignition lock cylinder.
Disconnect the electrical connectors from the ignition switch housing.
INSTALLATION PROCEDURE
Connect the electrical connectors to the ignition switch housing.
Install the ignition lock cylinder into the ignition switch housing. Turn the key to the OFF position. Remove the key. Position the ignition switch to the instrument carrier.
Install the ignition switch bolts.
Tighten
Tighten the ignition switch bolts to 10 N.m (89 lb in).
Install the instrument panel (IP) cluster trim plate bezel.
Install the knee bolster bracket.
Install the steering column filler panel.
Connect the battery ground (negative) cable.
I can email a couple of picks that might help also
Thumbs up
thanks - except for mentioning the "kind of expensive" part. I didn't want to hear that..
Is it just a new ignition switch you had to get or something more than that? About how much did it cost you to repair so I know how much damage to expect.... Thanks again
Old 04-05-2005, 08:50 PM
Wow!! Talk about getting some detailed help.. Very much appreciated. It doesn't get much better than that!!!! I"m going to attack this over the weekend.....
Thanks again
Old 04-06-2005, 06:58 PM
The part I was told runs about 76.00 and that's from the internet. From the dealer it is about 300. I Haven't been able to do it yet but will need to real soon as we are about to have our second child and I don't want my wife to be stuck.
Old 04-06-2005, 07:31 PM
it's amazing how bad the dealers rape you on prices - I'm going to do some searching and find it online. Thanks again for the info and congratulations on the new baby!!
Old 04-06-2005, 08:59 PM
MCO_Death MCO_Death is offline
Send a message via AIM to MCO_Death Send a message via MSN to MCO_Death Send a message via Yahoo to MCO_Death
Taking a car to a shop always results in the "kind of expensive" area.
