Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-01-2005, 06:39 PM
riff22 riff22 is offline
safc2 help!!!
i have a 95 tsi, list of mods ordered 255lph fuelpump, 550cc injectors, safc2, evo3 GT (16g fully ported), boost gauge, a/f gauge. my questions are. i read for the safc2 thr-points for low should be 35% and high should be 50%, wouldnt you want hight to be 100%? if not what are some good settings? and my other question is what would be a good boost to run at the track? and everyday driving?
thanks,
tyler
Old 04-02-2005, 01:01 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: safc2 help!!!
Did you read kpt's SAFC guide on tuners?
Old 04-02-2005, 01:24 AM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: safc2 help!!!
http://www.racingknowledge.org/topic...tuning%2Cguide
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 04-02-2005, 05:07 AM
Whathits14 Whathits14 is offline
High throttle is usualyl 50% because usually if you are puttin 50% down, you aren't just driving lightly. Do a lot of research before you start with the SAFC as if you don't know what your doing you can kiss your engine good-bye! (haha well if you have a 97 7bolt u just might not mind...lol)
Old 04-02-2005, 06:30 PM
i have read the manuall and the thing from rre just still had a few questions, i guess i dont fully understand what it does. so when you set it at 50% thr does that mean that it runs higher fuel at anything higher than 50% throtle?
