Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-01-2005, 04:42 PM
ringsincorona ringsincorona is offline
Send a message via AIM to ringsincorona
problem starting
Okay I have a 91 honda crx hf with a 88 integra DOHC zc engine and just recently the car no longer starts, ive tried two different starters and neither work. i can hear the fuel pump going off when i try and start it but thats about it. some people have told me check the clutch switch, its not stuck and becomes depressed so thats working fine. any ideas?
Old 04-02-2005, 10:05 AM
Re: problem starting
anything?
Old 04-02-2005, 12:41 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
ok so you turn the key and the starter doesnt go at all right ?
first chekc all your fuses to make sure they are good. seceond could be a bad starter, even though its unlikley. get a remote starter and try that, if it works then you know its the starter. third check to see if theres power going to the solenoid, if there isnt check to see that theres power going out of the ignition switch, kinda see what im getting at. i can help you further once youve done all those things
Team Lonely Drivers
Old 04-03-2005, 09:08 PM
fuses are good, solenoid is built into the starter so i know that works.
going to try ignition
Old 04-03-2005, 09:12 PM
Team Lonely Drivers
