Old 04-01-2005, 03:37 PM
Earlsfat's Avatar
Earlsfat Earlsfat is offline
Cheesesteakoholic
Burning Oil?
I've noticed that every 100 - 200 miles my maro seems to be about a half quart of oil short! It smokes SLIGHTLY when starting it up, and only for a second or two. I haven't noticed smoke from the exhaust otherwise. There is no antifreeze in the oil, or vice versa.
I check the oil every time before I drive it, and it's dissappearing a little at a time because I haven't noticed it when I check it. It's not leaking from the oil pan, The bottom of the engine is grimy, but I don't think it's totally covered with oil. There is a tube with a metal thing in it that comes out of the passenger side valve cover and goes someplace by the back of the carb / distributor / air cleaner, that occaisonally comes loose and falls out, but it hasn't done it lately so I know that's not the cause either.
Engine is a 454, with god only knows what modifications.... Anyone know if they burn oil???? I remember hearing someplace that SOME oil consumption is normal, but a half quart every couple hundred miles? Seems a little much to me.
Cheesesteak..... It does a body good.
"All you want to talk about is money, let's talk about love, and sex... forget love, let's just talk about sex. "
Old 04-01-2005, 03:52 PM
testtube's Avatar
testtube testtube is offline
Sorry for being off topic, but is that 454 in that camaro in your sig? If it is, thats frickin bad ass!!!
Old 04-01-2005, 03:54 PM
justinsz8's Avatar
justinsz8 justinsz8 is offline
Re: Burning Oil?
sounds like you need new valve seals, if it smokes a little when you first start it then it's fine after that. they're pretty cheap to have done.
Old 04-02-2005, 11:02 AM
Earlsfat's Avatar
Cheesesteakoholic
Re: Burning Oil?
Yep, 454 is in the sig pic. I knew it would be expensive to run, but christ man, Sunoco LOVES me.
Old 04-02-2005, 11:36 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Burning Oil?
i had that problem on another car i had. The oil pan was a little wet with oil too, so i tightened all the oil pan bolts and the problem went away.
Old 04-02-2005, 03:08 PM
Earlsfat's Avatar
Cheesesteakoholic
Re: Burning Oil?
Thanks Geno, I planned on going through the entire car tightening up every bolt & fastner I can reach when I get a chance. I didn't think about doing that on the engine stuff though. Only problem is... Do ALL engine bolts, etc need to be torqued or can I just go and crank 'em down? If they need to be torqued, I would have to find out the values for the specific motor I have right? Or are they all the same?
Old 04-02-2005, 04:13 PM
Genopsyde's Avatar
The President
Re: Burning Oil?
i would say torque specs on a car that came stock with a 454 would be ok, might wanna PM rob about it tho. he'd know better than I would.
