Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 04-01-2005, 03:36 PM
stefy1066 stefy1066 is offline
what's shakin???
Why does my 96 K1500 Burban shake so much when I step on the brakes? Usually when I'm going down hill. If I have anything in the cup holder it just about flies out. Any guesses??
Old 04-02-2005, 04:02 AM
EKJ EKJ is offline
Re: what's shakin???
Replace brakedisk and drums, pads and brakeshoes, and inspect oil seals on rear axel for leake!
Old 04-02-2005, 04:03 AM
EKJ EKJ is offline
Much brakedust in the rear drums can also make this happen
Old 04-02-2005, 07:10 PM
mrrpm mrrpm is offline
Best bet is probably on front rotors. If they're warped, it can cause a vibration. You may be able to turn them and solve the problem. Usually I end up replacing them, though. Big heavy vehicle = Hard on brakes.
Old 04-06-2005, 10:12 PM
J-Ri's Avatar
J-Ri J-Ri is offline
I would definately replace the rotors. If they are as bad as you describe, they may have to be turned past specs before they are true. Even if they could be turned true AND within specs, enough heat to warp them will often crack them. Also, larger vehicles create more heat when stopping, and thinner metal means they'll overheat quicker than with new rotors (usually only a concern when towing trailers or driving down long hills).
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
