Old 04-01-2005, 03:35 PM
Geometrodriver Geometrodriver is offline
need wiring diagram
I just got a 92 Metro and swapped the motor out. I need a wiring diagram. I can't find the wire for the starter. Can anyone help me out? Thanks.
Old 04-01-2005, 05:07 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: need wiring diagram
it comes out of the harness with the alternator wiring
Old 04-01-2005, 05:18 PM
Thanks. There is 2 wires that lead to one connector. They don't go to the starter, where do they go?...to the altenator?
Old 04-01-2005, 05:20 PM
Crvett69's Avatar
the round connector with 2 wires plugs into back of alternator, should be about a 3/4" round green plug. then there is a large wire with round terminal on the end, it goes to the stud stickout out of the back of the alternator, 10mm nut holds it on
Old 04-01-2005, 05:22 PM
tude123 tude123 is offline
If this connector is a bare metal loop it is a ground connect that ties onto the back of the throttle body via a 10mm bolt. Don't try to start your car without this ground being in place, it could lead to real problems.
Old 04-01-2005, 05:23 PM
Crvett69's Avatar
the one with the bare metal loop is usually 2 or 3 smaller wires going to the conector
Old 04-03-2005, 01:07 PM
Thanks. We have it figured out. Finally got the car running. Now just need to get it quiet!
Old 04-08-2005, 12:25 PM
trakout trakout is offline
[font=arial]fdsadfs[/
hey, i'm new to this thing, but i was wondering if you could help me out too! I just got a 92 geo metro with a suzuki turbo engine in it. if you still have the wiring diagram, could you send it to me (my username is trakout, and my email is [email protected])? thanks!
