Old 04-01-2005, 12:45 PM
systems systems is offline
Question 97 3.0 Cylinder #6 Misfire
I have a 97 Plymouth Voyager 3.0 V6 that has trouble code (Cylinder #6 misfire). This happened after changing timing belt/water pump. Still runs fairly well though it does idle rough. If anyone knows anything on this matter, please respond.
Old 04-01-2005, 01:29 PM
yoji6365 yoji6365 is offline
Re: 97 3.0 Cylinder #6 Misfire
sounds like you didnt get the timing correct. You might have to do it over again
Before you do that, check the spark plug and wire.
Old 04-01-2005, 03:37 PM
fishing1000 fishing1000 is offline
Re: Re: 97 3.0 Cylinder #6 Misfire
If it gets worse over time, it could be that the timing belt was not installed properly.
