Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 04-01-2005, 11:45 AM
edsel edsel is offline
brake to floor!!!!
went to repark car this am. stepped on brake no problem. made u turn and went to repark across the street and pedal went to the floor. stepped on it again it went back up. need clue to know what problem is thanks edsel. sorry i have a 1992 cierra 3.1. thanks...
Old 04-02-2005, 09:35 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: brake to floor!!!!
The master cylinder is bad and leaking past the rubber, plunger...whatever they're calling the cup rubbers nowadays. When you push easy on the pedal it goes to the floor but if you stomp it it'll hold somewhat. Replace that thing...the brakes hafta work EVERY time.
Old 04-03-2005, 11:44 AM
Ryan066 Ryan066 is offline
check for leaks before replacing stuff...
a weak spring could have failed.
Old 04-03-2005, 08:27 PM
AF - Advisor
Do you mean a spring inside a caliper?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 04-05-2005, 02:56 PM
in the drum... but then again it prolly would lock up... but I would inspect everything...
or do the test where u clamp (dont use vice grips(use something smooth like a round bar of somesort)) all brake lines (flexy/rubber ones (i wouldnt do it if they are really old)) and then press the brakes.... if they still go to the floor--- then the master cylinder is bypassing like you(christ) said. and then remove clamp by clamp, if it is good then it should be hard ... if it goes to the floor, theres ur problem.. if they all go to the floor theres air in your lines.
i dunno... most liky if there is not leaks it prolly bypassing in the master cylinder but its not really a commen problem i dont think
