Old 04-01-2005, 11:03 AM
anarchy1114's Avatar
anarchy1114 anarchy1114 is offline
Send a message via AIM to anarchy1114 Send a message via MSN to anarchy1114 Send a message via Yahoo to anarchy1114
Talking New engine
finally got a new engine in the GS and for $100 deductible on my extended warranty.
which is crazy becausse i was the dumbass that deprived my number one cylinder and spun the rod bearing bad a also scared the crank. to make a long story short me and a friend replaced the rod bearings, cleaned the metal out of the oil, put new oil in and it was still knocking. so i took it to the dealership under the extended warranty (had like 4,000 miles left to go) and they said they would replace the motor with a low milage motor. they couldn't find a low milage motor so they ended up giving me a rebuilt motor. so i'm almost done with the break in proceess and am ready to get the car back on the market. so if you have any advice on how i should market the car or if anyone is interested in picking it up. i'm looking to get 7 grand out of it.
If it has tits or tires it will give you problems, but atleast you can fix the problems with the tires
2007 Trailblazer - stock
97 GS-T -> lots of mods
98 GS ->total loss, now being parted out
Old 04-01-2005, 11:24 AM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: New engine
well first off you cant just replace the bearings when there spun, you need to replace the whole bottom end ,depending on what bearings you spun.
the car is only worth as much as someones willing to pay....
PS: your signature is alittle old... you need to update it....
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 04-04-2005, 11:03 AM
Re: New engine
yea i will my laptop isstill down so i don't have constant interenet access otherwise it would be updated. other than that anyone still have any good ideas on how i should market the car in order to move it any faster.
