Old 04-01-2005, 10:47 AM
george536's Avatar
george536 george536 is offline
Ported and Flappered or not?
Well as i posted a thread earlier about blowing my evo16g tdo5, and getting the China GT one. I have decided to sell it. I have decided to kjust get the real thing with dyno numbers proven. The GT is pretty freaking strong though it almost seems exactly alike. But i rather have the real thing.
My question is should I get it ported and flappered? Or just ported? I wanna get something im going to be happy about and not change it.
Knowing me i'll probably blow it in like 2 days
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 04-01-2005, 12:58 PM
joemathews's Avatar
joemathews joemathews is offline
Re: Ported and Flappered or not?
If the Evo GT is working well, and you're happy with it, keep it! It's not worth the hassle and money to get the real one if you already have a GT installed, IMO. Speaking as someone who just did this to 3 turbo bolts:
the fewer turbo swaps you do, the less hassle! I would run the EvoGT until it blows--or maybe it won't!? You can get it on the dyno, and set the standard for numbers on this turbo.
In other words, I think it would be worth keeping the turbo on the car if you're happy with it. As an added bonus you would be testing the turbo for its longevity and power capabilities
But to answer your question, I would get the turbine housing ported and the 34mm flapper if you're running low boost as a street car. If you want to deal with creep and you want to be able to hold 27 psi at the track on race gas, don't get the flapper.
Another thing to consider is getting the turbo and putting a 7cm housing on it...no port job, just a 7cm housing like ShapeGSX has on his 11second Evo16g.
1996 Eagle Talon
Old 04-01-2005, 03:07 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
is this the turbo your talking about??
http://www.slowboyracing.com/evo3vsgt.htm
DSM geek
Old 04-01-2005, 03:09 PM
george536's Avatar
yea, true i am happy with the turbo, but i rather just get the MHI one. Oh well
Also, i want to get one of those Y pipe cutouts thats on the downpipe. I cant find the link. Anyone got it. I want to have a switch so i can race and then quite for daily
-1990 Eclipse GSX
Old 04-01-2005, 03:12 PM
http://www.quicktimeperformance.com/...uct_detail&p=3
DSM geek
Old 04-01-2005, 03:25 PM
george536's Avatar
Im thinking of putting that cutout on my stock DP. Since i have 2 stockdownpipes and can switch it when smog comes. I turned on the car with no downpipe, and it sounded crazy mean like you wouldnt believe. My neighbors came out thinking its a muscle car. it was hilarious.
I kinda liked the thought at being at a light with a muscle car next to me, flipping the switch and sounding mean as heck.
-1990 Eclipse GSX
Old 04-01-2005, 04:03 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
theres acouple sleeper cars around here that have that.... they have a high flow downpipe and then place that vavle in place of the cat , and then bolt on the stock exhaust after that.... he drives around with the exhaust exiting the stock cat-back and when some one wants to race he flips the switch and it bypasses the catback and dumps straing out under the car.... instant horsepower...
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
