Old 04-01-2005, 10:08 AM
cody911911's Avatar
cody911911 cody911911 is offline
overheating head unit
ok I'm back again after a winter off of this my headunit a older pioneer is overheating during this winter after about an hour of usage this winter but now I hooked my subs back up and it didn't overheat in an hour and a half what kind of sense does that make? I dunno.....maybe I need more tests.
1st rule of drinking and driving.......you gotta have a beer.....
Old 04-01-2005, 11:08 AM
AndonD454's Avatar
AndonD454 AndonD454 is offline
Send a message via AIM to AndonD454
Re: overheating head unit
maybe you werent playing the normal channels (speakers) as loudly as before now that you got your subs.. but this would only make sense if you listen to your music with your bass overpowering your speakers...
anyways.. do you have any of your speakers connected together? my friends was doing this because he had both right speakers tied together and both left tied together. thsi would lower final impeadence to 2 ohms (if you have 4 ohm speakers) and most head units arent stable at 2 ohms.
check to see how it is wired
1996 Explorer 4.0 V6 4x4
Sold all my shit.
waiting for more money
Old 04-01-2005, 11:39 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
do you use your heater a lot in the winter?
a lot of times the vents pass right over the headunit, if you're using the AC it will keep the headunit ice cold and if you're using the heater it can heat it up quite a bit. Now that it's warmer outside you're using the heater less so the headunit is staying cooler. Just a thought...
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 04-01-2005, 01:57 PM
cody911911's Avatar
na the channels are broken up because i can fade and balnce the stereo just fine it might make sense that the heater was doing it but i run with it on low he whole time and it might infact be that because my car only has vents and a deroster no foot heater, and I wouldn't know about AC because it aint warm enuf yet for it and if my memory serves me correct the AC is not cold at all anymore.
