Old 04-01-2005, 09:53 AM
tdag tdag is offline
bogging problem
1982 camaro 5.0 the car has a rochester quardrajet, a holley high rise manifold single plane and a cam that is one step up from stock, the car runs good until I open the secondarys then it totally boggs out. I replaced the rochester with a new holley 670 street avenger and its does exactly the same thing, totally boggs out when I open the secondarys can anyone help me with this problem? thanks
Old 04-04-2005, 12:57 AM
Morley Morley is offline
Probably the secondary metering rods. Either too much fuel or too little when the secondaries are opened.
Old 04-04-2005, 12:47 PM
michaelmeck michaelmeck is offline
Re: bogging problem
I agree with the above. Also, Does the carb have vaccume or manual secondarys? if they are manual they may be opening at too low rpms and flooding the engine
Old 04-08-2005, 12:18 AM
Vortec350S10 Vortec350S10 is offline
Re: bogging problem
If this problem is happening with both carbs, I would bet you are having a fuel pump problem. Hook up a fuel pressure gauge under the hood and rev it up with your hand and see if it is the problem. You should have at least 3-4 psi at WOT.
'89 S15 4x4 350TBI/700r4
restored body, paint,
3" lift, crane cam, vortec heads
'88 Iroc 350 carb, TCI 700r4, 380hp
Old 04-08-2005, 02:48 PM
Re: bogging problem
sorry its not manual its vaccumn
Old 04-09-2005, 07:28 PM
demon9766 demon9766 is offline
Send a message via Yahoo to demon9766
Re: Re: bogging problem
Well if both carbs are doing the same thing it is your fuel delivery .I would get a better pump.
