Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 04-01-2005, 04:09 AM
Baumann_Yayo4G Baumann_Yayo4G is offline
Send a message via MSN to Baumann_Yayo4G
Unhappy help me wit my valve clinking??
how do i fix the rattleing in my valves ..it sounds liek theres a loose valve..but wut do i tighten??? help me
Old 04-01-2005, 04:12 AM
Re: help me wit my valve clinking??
help meeee. its a 1990 civic dx...dual point but ..im outtin' a multi point in'er this weekend
Old 04-02-2005, 11:06 AM
97integrals's Avatar
97integrals 97integrals is offline
you need to adjust the valve lash
Old 04-05-2005, 03:40 PM
clutcher clutcher is offline
Also, make sure your spark plugs are tight.
Old 04-05-2005, 05:01 PM
londa hover londa hover is offline
Take off your valve cover, then tighten your intake valve springs with a torque wrench to 7psi, and your exhaust springs to 8psi.
Old 04-05-2005, 10:13 PM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
Check The Haynes Manual, Or Any Other Manual, Its Called Valve Clearance Check And Adjusting, It'll Require A Feeler Guage, A Flat Head Screw Driver, And A 10mm Open Wrench.
Old 04-06-2005, 03:29 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
yep i recommend the Helm manuel. Honda uses them to publish all thier OEM service manuel. go to www.helminc.com to order one.
