Old 04-01-2005, 03:31 AM
halo676 halo676 is offline
Send a message via Yahoo to halo676
'92 blazer ignition module
Okay out there, how do I change the ignition control module on a '92 Blazer 4WD 4.3 V6 TBI Engine? I've searched the forum and found nothing so far...So I thought I'd ask...
Old 04-01-2005, 06:43 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Unplug the wires at the distributor, remove dist cap. Remove rotor. remove both 7mm screws on module, lift out. Replace in reverse, put about a 1/4" layer of dialectric grease on the bottom of the new module. (Or you will be replacing the new module in a month due to heat damage)
Old 04-01-2005, 10:39 AM
thank you very much!! It worked!! Just so I would know though, how could you be able to tell if the coil went as opposed to the module?...
