Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-01-2005, 02:25 AM
Nedi Nedi is offline
White smoke and Oily Plugs
Hi Guys
Here is my problem
I have Honda Civic 1989, one night I noticed loss of power so I checked my spark plags and found out one of them was bad. When I replaced I noticed oil around plug, anyway I changed the plug and car seemed to be fine. The other day I went to mall without any problems but when I came from the mall and started the car there was alot of white smoke coming out and car seem to be straggling to stay running. I went and replaced all spark plugs and 3 out of 4 were oily. After replacing spark plugs car seemed to be fine again but going home I noticed my temp gauge was high so I pulled over and added pre-mixed antifreeze and temp gauge went down and I came home with no problems. One day later my temp gauge was running high again, and I was missing coolant, there are no signs of external leaks and sometimes white smokes comes on and car is straggling to say on.
Any advice would be appreciated
Old 04-01-2005, 04:03 AM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
I think it's time for you to decide if it's worth the money to replace a head gasket set for your engine.
Is there anymore signs of oily plugs after you changed to the new plugs?
For the oily plugs, I think the valve seals are going bad (should check your engine oil level since it seems like you are loosing oil also)
As for the coolant consumption, most likely the coolant is being pulled into the cyclinder and being burn (bad head gasket). That also explain why you have white smoke coming out of your tail pipe.
By changing the head gasket set, it should take care of the problems you have.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 04-01-2005, 01:53 PM
Re: White smoke and Oily Plugs
Thanks Tofuboy for your replay
Let me update you on today status of the car.
I went down and check my spark plugs for oil and guess what there was none. I added coolant and started the car and there was no smoke and car run fine. When it wormed up to normal operation I checked again spark plugs for oil and there was none. I turned off the car and started it again, small puff of smoke came out and then stoped smoking and run fine again.There is no shortage of oil, if anything looks more then it should be. But it does not look milk-shaky .
Old 04-01-2005, 03:01 PM
95cord 95cord is offline
its prolly not your head gasket, if anything it should be your valve cover gasket. i had the same problem in my probe and it was the valve cover gasket. if it was your head gasket you would see water in oil or oil in water and would prolly experience overheating.
Old 04-01-2005, 03:27 PM
97CivicX's Avatar
97CivicX 97CivicX is offline
Send a message via AIM to 97CivicX
it would have nothing to do with the valve cover gasket, at all. my guess is the headgasket is blown. its a pretty common problem with civics when the millage gets up there
D16Y7/D16Y8 mini-me swap
turbo coming this summer
Old 04-01-2005, 04:26 PM
The mileage on this car is only 70k miles I bought it from old guy who had all records and nice maintenance on it. Today I found out where my coolant is going. It's coming out on the tailpipe even when there is no white smoke tailpipe is very wet and smoke is very moistured. I lost about 4 L of coolant on 100 miles even dought it was not smoking white smoke all the time. Any suggestions is good and thanks for replys.
Old 04-01-2005, 04:38 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
as mentioned many time before.... head gasket
Old 04-02-2005, 12:24 PM
Brizow Brizow is offline
Head gasket. Check your the coolant lines. Make sure you don't have a crack in one. If you are burning coolant it will smell kinda fruity.
I would definately check that head gasket it sounds like that is a definate problem. Are you running a D15B2? The miles you said arn't real high. But the 1.5 heads aren't the greatest. I have a 91 Civic and know that all to well. Pull the head off and check.
If you need some help with that just ask, or I suggest you get a Hayes manual if you don't already. They are a big help. I hope you get everything worked out man.
Old 04-02-2005, 01:44 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
theres no way for the coolant to get into the engine other than into the combustion chamber, so its either a headgasket or worse
Team Lonely Drivers
Old 04-02-2005, 04:38 PM
Thanks guys for all your input. I am getting shop manual for this car and I will tackle this myself because I dont think it is worth paying $1000 dollars to a shop. So if I screw up then I will just look for another car.
Old 04-02-2005, 10:09 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
that old of a car with that low of miles can be just as bad if not worse than same year high mileage. But yeah, i will go as far as to say ot "is" a head gasket, or warped head or warped block problem. Everything you said points directly to it. Or you could have a slight crack in the cylinder wall, but that is highly unlikely.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 04-02-2005, 11:43 PM
Tofuboy's Avatar
Good luck on your repair Nedi.
If you have any questions just post them, I am sure some of us will have answers to your problems.
FYI. you might want to change the water pump, timing belt and tensioner in the process of changing the gasket set, this way you can save yourelf some labor also.
Welcome to AF
95 Civic EX
83 Toyota Starlet
Old 04-03-2005, 02:22 PM
Old man changed water pump and timing belt when car had 47k miles so I would assume that should be okey.
Old 04-04-2005, 01:19 AM
Hi Guys
I found site where to download service manuals for Honda Civic maybe it will be useful for some of you that have this type of car. Unfortunatly they don't have one for my type of car but I downloaded others and I think I got pritty good idea what it takes to change Head Gasket. Two things I need are
One is how thight Cylinder Head Bolts should be and sequence
Other is I can't determine what is my engine type. I obtained following information about my car from carfax
Year/Make/Model: 1989 HONDA CIVIC DX
Body Style: Sedan 4 DR
Engine Type: 1.5L L4 FI
Manufactured In: JAPAN
The site for Service Manuals is
http://download.honda-fanatics.nl/manual/
Old 04-04-2005, 02:42 AM
second from the top. just go to napa and buy a haynes or chilton manual. alot easier.
Team Lonely Drivers
