Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 03-31-2005, 11:53 PM
KaisenH KaisenH is offline
240sx owner...need some info on 300zx brakes
Whats up guys, i own a 240sx but i am doing a brake swap on my car. I am putting on 30mm aluminum 300zx calipers and brembo rotors on the front. I already have the stainless steal conversion lines and brake pads. I now need to order a caliper hardware kit consisting of pad pins, pad
spring clip, and pad pin clips. My question is how of each are required for EACH caliper. Im not 100% sure but i think its 2 pad pins per caliper, 1 spring clip per caliper, and 1 pad pin clip per caliper. Is this right?
thanx for helpin out a fellow nissan owner!
shift_baby Z
Old 03-31-2005, 11:54 PM
ExTrEmEDrIfT's Avatar
ExTrEmEDrIfT ExTrEmEDrIfT is offline
Send a message via AIM to ExTrEmEDrIfT Send a message via MSN to ExTrEmEDrIfT Send a message via Yahoo to ExTrEmEDrIfT
Re: 240sx owner...need some info on 300zx brakes
yah i think tahst right
Past Z Car Crew
[The Enemy Of Your Enemy is Your Friend]
>>Keep Your Friends close : But Keep Your Enemies Even Closer <<
Old 04-01-2005, 11:39 AM
Hodo Hodo is offline
been a while since I didnt my brakes but that sounds about right. Check out 300ZXclub.com I am sure there is a online manual for the 300ZX Z32 chassis on there, and you can check for yourself to see what all is on the brake calipers and all.
Finaly got pics of my car....... after I washed it of course.
Old 04-01-2005, 07:03 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
there is 2 pins but everything else is right...
and you should have gotten the 30mm iron calipers...the aluminum's have a tendency to warp after so many miles and heat. but i think nissan caught this "problem" after the first year of production on the Z32.
ZedEx Crew Member #4
