Old 03-31-2005, 07:22 PM
dltf90 dltf90 is offline
Help with the sub section of a 5.1 system
Car stereo's aren't really my domain of knowledge, home theater is. So I want to get some ideas from people that are more in the know. I have a 2001 Maxima SE that I'm putting in a Pioneer AVH-P7500DVD HU. The reason for this HU is the DVDa 5.1 capabilities as I'm a DVDa authorer. I have nice componet speakers in the front and combos in the back from a previous system with a decent amp (Alpine 4 channel).
The big issue I have is an older, not well thought out, 2x 12" subwoofer setup. It can go. I'll save it for use in a new truck next year. The current box just doesn't sit right in the trunk at only 32" wide. It litterally crushes and sinks into the spare tire wheel well. I was considering a 38"W x 14"D x 12"H generic 3x 12" pre-fab box. That width would litteraly fit snug from wheel well to wheel well. It would also elevate the box in the middle to a couple of inches above the cover for the spare tire. I'm more concerned with hauling grocieries than showing off any speakers.
My problem is I don't have a table saw or decent equipment to build my own custom box. I'm not looking to impress anyone with my bass capabilities as I am an audiophile, not an attention seeker. I'm looking for a recommendation on good subs and amp (preferably one) that would work for this setup. Or, alternative suggestions if my ideas are misguided. My budget is about $1000. Thanks.
Old 03-31-2005, 09:44 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: Help with the sub section of a 5.1 system
since your goal is sound quality and not SPL I would seal a single 15" sub. Try to find a used brahma 15 from adire (they are not in stock at adire and won't be again). Or you could seal and avalanche 15 from ascendant audio www.ascendantaudio.com
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 03-31-2005, 10:17 PM
Re: Re: Help with the sub section of a 5.1 system
My worry about 15" drivers is the flabby bass response. Generally I've found 10" and 12" drivers to respond faster and give a tighter bass definition. I'm a thrash metal / prog metal fan, so I need bass that can respond. Is there something that makes this particular 15" driver respond with the speed and accuracy of a 10" or 12" driver?
Lastly, the position in which I can put the box for the sub has a height limitation of around 18". I don't know what the norm is for a 15" driver.
Old 03-31-2005, 11:06 PM
It may seem that way with usual mainstream crap, but these subs have linear motors (xbl^2) and are geared for ultimate sound quality. I installed an avalanche 18 recently and that and my friends brahma 15 are the two best sound quality substages I've ever heard. I've also head a LOT of 10's and 12's ported and sealed. From the sounds of what your looking for I think a brahma15 or avalanche 15 would be perfect!
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 04-01-2005, 06:52 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Re: Re: Help with the sub section of a 5.1 system
Ditto the above. You do not want a 15" for 5.1 dvd system. Oh, B-stang, don't even act as if you know what this is all about either. I'll warn others that he'll flame the snot out of you if you suggest anything other than what he suggests. Also dlt90, he can't give an exact answer to why he says this 15" doesn't sound muddy. He just give's his preference.
Since space is a concern I'd look into either 2-10" or one 12" woofer in a sealed enlcosure. The new SX line from DEI is a real treat http://directed.com/audio/subs/default.asp . They're nice and rugged, very responsive and work well in a small sealed enclosure. With over 2" of usable cone travel, they'll pound great and clear for those heavy metal notes. I love how they sound with my old Metallica tunes!
You'll want either the d1200 amp for one sub or d2400 for 2 subs. Both of them are classD mono amps just for subs. Again, these things are pretty hefty items.
No matter what you choose to do, you really need to have a proper custom box made to compliment your vehicle. Many people don't give much thought on the enclosure but that's one of the most important items. You gotta build the right box for the right subs for the right vehicle. If not, it just won't work at the full potential.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 04-01-2005, 09:18 AM
DEI SX= not a flat response at all..... needs a HUGE box to get anything sub 40hz decently when sealed. Honestly man check out brahma and avalanche 15's they sound great. Talk to sr20 who's on here he runs a sealed brahma 15 and haas your listening tastes and couldn't be more happy with it. Obviously poncho has no clue what a good 15 is with his description above..... brahmas and avalanches are some of the best sound quality subs period. Also check out Image Dynamics IDmaxes and RE xxx's.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 04-01-2005, 01:20 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
The problem with this question is it starts with the assumption that 10's and 12's are somehow magically "faster" than 15's. Since that's completely untrue it's kind of hard to answer you.
God I don't even know where to begin....I guess I'll just start by asking why you think 10's and 12's are faster? If you feed a sub a solid tone it will play that tone, which means it MUST oscillate a certain number of times per second (also known as the frequency, measured in hertz). If a sub was "slower" it wouldn't oscillate as many times in that one second period and essentially it would be playing a different frequency, which we know is impossible.
Or do you mean it doesn't respond as quickly to transients? If so then why not? Because the cone weighs more? So what? Sure given everything else equal it would accelerate slower, but it will still start at the same point in time, reverse direction at the same point in time, and stop at the same point in time. It just won't move as far as a sub with a lighter cone. But this is holding everything else equal, all the sub manufacturer has to do is tweak the suspension a little to allow the cone to move farther on a given amount of power and that completely takes care of that problem, now the sub with the larger cone will move just as quickly and effortlessly as the sub with the smaller cone, it's just sweeping more air while it does it because of the larger radiating surface.
I don't know how this stupid "large subs are slow" myth got started, my guess is it's a result of the mainstream brands shoving their subs in boxes that were WAY too small so people wouldn't instantly turn them down (small boxes are attractive, whether they improve or destroy the sub's sound is irrelevent). A smaller box will have a higher damping ratio, when the DR gets to be too high (~.8-.9) the sub's transient response suffers, no matter what sub it is. With smaller subs this isn't much of a problem because their optimum box size is small enough where people will still buy it, but the large subs require very large boxes, probably too big for the average person to want, so instead they stick them in small boxes to sell more and don't give two craps how it ends up sounding. So now you have people running around with 10's in perfectly matched boxes, 12's in reasonably matched boxes, and 15's in horribly matched boxes. Out of that comes the rumor that larger subs by nature are slow and sloppy while smaller subs are quick and punchy, when in fact it's the boxes that are bringing about these "conclusions". I'm not sure if this is accurate, it's really more of an educated guess, but one look at the boxes these mainstream companies stick their subs in tends to support it.
Besides, subbass by nature is pretty sloppy. I mean the reason why it's subbass is because the frequency is low, and low frequencies are slow. If they were faster then they would be higher frequencies, but they aren't, they're low. It's really the midbass that gives the subbass any kind of definition. Without midbass, subbass is just a series of rumbles, that goes for ANY speaker playing those frequencies. If you want the quick punch that is present in metal then you need to focus on your midbass, not your sub. Hell on most rock/metal songs you could go completely without a sub if you have strong mids.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 04-01-2005, 04:42 PM
sr20de4evr, that seems like a very good and logical conclusion. Personally, I really don't know. What I do know is that no one subwoofer or size is a cure all for everyone. In general, I do not like 15's in a car unless acoustially it sucks so bad it needs a 15 or even a 18. Also, not every 10 or 12 can be put into a small, sealed box and sound great in every car. Like I always say, everything is revalent upon everything. Oh, yes, you can easily have 12 or even 10's go below 20htz but in most cars, that's worthless. At that point that just rattles your nuts and isn't very audible. In the mid 30's on up is what you actually feel hit and can hear.
Pioneer 4900mp
Orion C63 Coax rear
Old 04-01-2005, 05:20 PM
While not an expert by any means on car audio, I do know a thing or two about home audio. My equipment consists of Krell, Classe Audio, PSB, VMPS (sub) and a 10' projector setup. (http://www.schloctar.com/pictures/theater/DCP_0601.JPG)
As for 15" drivers being slower than 12" or 10" drivers, it isn't a myth. It's simple physics. A 15" driver has more surface area and mass than a 10" or 12" driver. I'm sure there is no argument there. In a sealed box, it has more resistance to travel than a smaller driver because of the increased surface tension area. While it is right that a 15" driver can produce a continuous tone every bit the same as a 12" or 10"; the difference lies in the transient response times. That is where the "sluggish" or "muddy" sound comes in. Yeah, cars are anything but a perfect environment for audio, so I do think a grain of salt should be observed in most decisions and purchases.
Since I listen to a lot of bands like Rush, Dream Theater, Anthrax, Motorhead, old Metallica and the like, fast bass response is something of a concern. Besides, if any of you have ever used a frequency analyzer on you music, you'd be surprised to find much musical information below 30hz. So real low extension isn't that much of a musical concern as it is a home theater concern.
Yes, I'd love to build a custom box for my vehicle. However I lack the wood working equipment to do so. I have $10k worth of house projects to finish before I can get to even purchasing woodshop equipment. So I'm looking for a reasonable option to use for the next few years till I can do something more "custom".
I do like all the suggestions I've seen so far and it definitely gives me more to think about and plan. I like knowing about options I haven't yet considered or about shortcomings in areas I haven't noticed. I don't buy much on impulse and prefer to research all options first before making a decision. So I'm still open to suggestions and comments. Thanks.
Old 04-01-2005, 07:13 PM
dltf90, Well, I hope that what I have said will help in your decision and not just to persued you. It seems as if you have a very good hand on home systems which can relate to vehicles too. Obviously, just like you stated, vehicles are in no way a perfect place to make a perfect soundstage. That's were all those crossovers and special box designs and all come into play.
Whatever you do, hope it all turns out the way you intended.
Pioneer 4900mp
Orion C63 Coax rear
Old 04-01-2005, 07:55 PM
germanyt germanyt is offline
if your looking for 12 for sound quality i would have to recommend the punch p3. i own 2 of them and ever since i had a custom ported box built i couldnt be happier. i have not heard them in a sealed box so i dont know what they would sound like. i doubt the quality would decline. just so stang doesnt come back with how shitty my system is i am also goin to recommend the jl w3. i will say that 3 of them is going to be very loud. i have a buddy that had 3 12s in an extended cab dodge dakota. oh my god. that shit was loud. but aside from loud it had some of the best bass responce ive ever heard from a system. truly a quality setup. i know he was running a phoenix gold amp. no clue how many watts. he did it with just one amp though. maybe you could try the 10w3s and a amp with just enough power to get the kind of bass your looking for. i recommend audiobahn amps. i dont have one but i have installed them. i am very impressed. well, hope i helped you out.
(2) RE SX 15s (www.reaudio.com)
~6.5^3 net @ 35 Hz (polyfilled to increse vol. & lower tuning to 32 Hz)
(2) eD Nine.1s (www.edesignaudio.com)
1 Optima yellow top (www.optimabatteries.com)
1 Optima red top
200 amp alt (www.dbelectrical.com)
eDead V1SE2 250 sq ft
Big 3 (1/0 awg)
Pioneer DEH-P650 (www.pioneerelectronics.com)
Infinity Reference 5 1/4 comps (www.infinitysystems.com
Infinity Kappa 6x9s
MTX Thunder 3404
Power Acoustik TFT/LCD
Pyle DVD/CD/MP3/WAV/WMA player
Old 04-01-2005, 09:19 PM
sr20de4evr's Avatar
yes, it is a myth
Yes in a sealed box a sub with a larger cone WOULD have more resistance to movement because of the increased change in pressure, but you're forgetting one huge part of that argument....you put it in a larger box. The resulting change in air pressure is very similar to a smaller sub in a smaller box. The response of the speaker to a given impulse is defined by the Q of the speaker/box setup. If you've ever even dabbled in the effect of the damping ratio on the transient response of second order systems you'd know this.
And if you don't want to believe me:
http://www.adireaudio.com/Files/Tech...ooferSpeed.pdf
or just do a search on any car audio forum on the net
'01 Black Sentra SE
'05 Silver WRX STi
Old 04-01-2005, 09:59 PM
Originally Posted by sr20de4evr
yes, it is a myth. Yes in a sealed box a sub with a larger cone WOULD have more resistance to movement because of the increased change in pressure, but you're forgetting one huge part of that argument....you put it in a larger box. The resulting change in air pressure is very similar to a smaller sub in a smaller box. The response of the speaker to a given impulse is defined by the Q of the speaker/box setup. If you've ever even dabbled in the effect of the damping ratio on the transient response of second order systems you'd know this.
I have no desires to get into a flame war, especially on so subjective a debate as this. I agree, box types and sizes can have a very pronounced affect on performance. Just the same, what I stated is also equally valid. There are two differing positions on this, neither is right, neither is wrong. Audio is as much voodoo as it is science. People can hear things differently whether it is real or not.
In my case, I have my own empiracle observations that I draw upon to give me the conclusion I have over very large drivers. While not the best parallelism I have, I do remember demonstrating my theories to several of my friends when I was shopping for speakers about 8 years ago. I was thinking of getting either the Paradigm 7se or the 9se speakers. The only difference being that the 9se had an 8" and a 6" where as the 7se had two 6" drivers. CD after CD were demo'd and the same conclusion was reached by all. While the 9se had deeper bass extension, it sounded muddier and less detailed than the 7se with its smaller drive array. It has been very hard to break me of that philosophy ever since.
One pattern I do see is that my idea of the 3x 12" system is going to be overkill for my needs. I may need to be looking into a smaller sysem with perhaps a less than fancy, custom box. I don't know where to get one since the local shops in my area tend to cater to rich teens and wanna be thugs. Those places make me kind of uneasy.
Old 04-01-2005, 10:37 PM
sr20de4evr's Avatar
And it's not possible in any way that the 8" driver wasn't in a well-matched enclosure? Or maybe it wasn't designed as well as the 6"? Or maybe you were interpreting a more well rounded low end as a muddy sound? If the speaker cuts off at 60hz it will sound more "snappy" than one that cuts off at 40hz, just because that extra low end tends to blur the higher pitched "attack" that you have on kickdrums. I mean you're taking one specific example and jumping to this HUGE generality that encompases every speaker of different size....just imagine if your "test" had a different outcome. Maybe the dual 6" speaker sounded distorted on low notes and the 8/6 hybrid had a very solid low end, and then jumping to the conclusion that no 6" can play low, or a larger speaker can always play lower than a smaller speaker. You know how ridiculous that sounds right?
And yes I agree, 3 12's would most likely be too much, not to mention a huge waste of money. If you want a "tight" sound then stick with sealed, the higher group delay of ported, over emphasized low end, and sacrificed top end will take away from this crisp sound you're looking for. I say one sealed 15, but if you have a personal problem with 15's then a pair of sealed 12's. Just keep in mind if you go that way you're going to be spending nearly twice as much money on the subs, and nearly twice as much money on the amp, with a very very small increase in output vs a single 15. Brands to look at are Adire, Image Dynamics, Arc, and Ascendant Audio.
'01 Black Sentra SE
'05 Silver WRX STi
Old 04-02-2005, 01:38 AM
Yea man were not trying to start an big argument what so ever. It is generally assumed that 15's and 18's are more sloppy, but in the case of most audiophile level products this just isn't the case. Where are you located? It may be possible for you to hear some single sealed 15" setups using brahmas ect....
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
