Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 03-31-2005, 06:44 PM
batman19 batman19 is offline
Send a message via AIM to batman19
What else should i change?
i'm taking my front wheel off to change my rotor and pad this weekend, what else should i check and maybe change while the wheel is off??
Also, does anyone know how to work on drum break? What part do i usually need to change? i hear it is pain in the butt
1997 Civic HX
1.6 D16Y5 engine
Auto with 55K
STOCK
Old 04-03-2005, 06:19 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: What else should i change?
Pull, sand, regrease the slide pins. Grease all your joints while you have the wheels off.
As far as the rear, just the pads. Though if the adjuster is rusty, you should replace and readjust those. Doing rear pads are easy.
Old 04-04-2005, 10:38 PM
rear pad is easy? i hear that drump break is pain in the butt to work on.
Can someone point out all the grease point for me?
i saw two on the front wheel at each side so far? but i heard there is about 11 grease point, and where is the grease point for lower ball joint?
1997 Civic HX
1.6 D16Y5 engine
Auto with 55K
STOCK
Old 04-05-2005, 05:24 AM
rlith's Avatar
Inner and outer tie rods (both sides)
4 Ball joints (upper and lower)
Pitman arm
idler arm
u-joints (if after market)
Old 04-05-2005, 10:57 AM
OffRoadSonoma's Avatar
OffRoadSonoma OffRoadSonoma is offline
Send a message via AIM to OffRoadSonoma Send a message via Yahoo to OffRoadSonoma
Drum brakes are a pain in the ass. But if you have the brake spoon and other tool it is a little easier. It also gets easier the more times you do it, but your shoes usually last 50,000 miles or more, so you'll probably only do it once while you own your truck. rlith might have been thinking your truck was 4 wheel disc, but unless you upgrade, it isn't. As far as adjusting your drum brakes, put the shoes back on and the drum. There should be a little window in the drum that gives you access to the adjusting star. Turn the adjusting star to were there is drag when you spin the drum, then back it off 2 turns. After your wheels are on and you are ready to drive. IN AN EMPTY PARKING LOT, (make sure there are no cars around you) shift into reverse and go between 5 and 10 mph, slam on your brakes. Do this 3 or 4 times. Drum brakes have an auto adjust feature, and by doing this, it enables it and adjust the brakes to the proper tightness. Hope this helps.
Old 04-05-2005, 05:50 PM
hey, i dont think i have a grease joint for my lower ball joint, or at least i cant find it
1997 Civic HX
1.6 D16Y5 engine
Auto with 55K
STOCK
