Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 03-31-2005, 06:56 PM
zack1963 zack1963 is offline
Angry Tempo stalls,loose distributor
My friend's 1990 ford tempo stalls sometimes, i tried to help her with it cause i do not want her to get ripped off.
First i changed the plug wires because they were split and the plugs,the car started many times,and then after i took it for a test drive for about one mile then stalled and it wouldn't start again, after several tries,i started to check my snugnesh of the wires i realized the distributor is loose, cause somebody else she told me worked on that disributor.
Please tell me the steps involved to tighten that distributor.
Thank you so much guys.
Zack
Old 03-31-2005, 09:55 PM
mustangmike351c mustangmike351c is offline
should just be one bolt that holds it down it will have a mark on it were the bolt was holding it just get it as close to the old mark as you can
Old 04-01-2005, 10:22 AM
Re: Tempo stalls,loose distributor
Thanks Mike, i will try your tip.
Zack.
