Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 03-31-2005, 06:24 PM
Alan999 Alan999 is offline
Performance between SI and VTEC
Hello prelude enthusiasts…
I was wondering how the gas mileage was for people who have swaped their 2.3l for a VTEC engine. In a regular commute (not racing) do you all feel that the mileage that you are getting is better from a 2.2 VTEC engine than a 2.3l engine. Or would you say there is no difference…. Any opinion is appreciated….
Also is it true that the VTEC engine burns (or consumes) oil….that u have to keep a watch on the oil level constantly.
Thanks for your in put in advance…..cheers
Old 03-31-2005, 07:03 PM
Gohan Ryu Gohan Ryu is offline
Re: Performance between SI and VTEC
I own a 92 si and a 96 vtec and the 96 gets slightly better gas mileage. If I drive the 96 with a heavy foot (always in vtec) then the mileage suffers, but I always get better mileage with the 96. BTW my 96 is in better shape my 92, so that might have something to do with it. Both engines are mostly stock.
Old 03-31-2005, 08:07 PM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
Yeah it is true that the VTEC engines use oil, mostly due to the high RPM's. Mine really doesn't use any oil, i had a slow leak that I had fixed and the most i'll have to put in is half a quart in between oil changes, if that. But especially when the miles start to get higher, they do have a tendancy to burn oil.
Old 03-31-2005, 11:12 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Re: Re: Performance between SI and VTEC
I also own a 96 VTEC. This might be a long shot but I think the fact that they're OBDII has something to do with them having slightly better gas mileage. OBDII cars will tend to run within certain a/f parameters to keep them emissions friendly. While if an OBDI car tends to run rich, it will continue to run rich without much correction from the ecu, thus using a bit more fuel.
Old 04-01-2005, 11:06 AM
Re: Re: Re: Performance between SI and VTEC
Yup, I agree - my 92 always has that black carbon burnt-fuel residue on the tailpipes from running too rich - keeps coming back after I clean it off. The 96 tailpipes stay pretty clean.
Old 04-01-2005, 12:00 PM
I never even thought of that. My 94 has the burnt fuel residue on the tailpipes too. I know that they're known for running rich at higher RPM's too. You think a dyno tune with a VAFC to lean it out a little would increase gas mileage?
Old 04-01-2005, 02:02 PM
SiGNAL748's Avatar
Well, Honda motors, especially VTEC's, will tend to run rich by default. Honda tuned them that way as somewhat of a safety precaution (to prevent detonation). I suppose that if the person tuning your car knew what he was doing, it shouldn't be too much of a problem.
Old 04-01-2005, 05:20 PM
Yeah I knew it was to prevent detonation. I think it might have been AcesHigh who posted it some time ago, but he had the A/F ratios at different RPM's, and apparently there's a decent amount of power that can be freed up. Like you said though, as long as the person knows what they are doing.
Old 04-01-2005, 06:13 PM
SiGNAL748's Avatar
Where's Aces been lately anyway? He had some pretty good faqs going a while back.
Old 04-01-2005, 06:24 PM
Thanks guys for your input...
How about others with vtec do your engines burn oil as well with you vtec motors. Is it a problem that occurs when you run at high rpm or does the vtec burn oil as part of its normal operation. Also does this problem occur on the 2.3l engine as well..
Thanks guys i'm just trying to make up my mind between a si and vtec,
Alan.
Old 04-01-2005, 06:42 PM
Yeah Signal, I was wondering the same thing, he seems to come and go, but he knows his stuff.
To Alan999, if you can get the vtec, it's no question, get the vtec, it's so much fun to drive. As long as the engine is taken care of, the amount of oil consumed is next to nothing. It shouldn't consume more than 1 quart between oil changes. Unless you plan on boosting, go with the vtec.
Old 04-10-2005, 10:44 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Hello everyone, apologies for the recent absence.
Anyways VTEC doesn't burn any more oil than a standard engine, although it is true that oil is an especially important component. Much like a turbocharger, without oil running there would be no VTEC operation. It uses a little extra oil, but it won't necessarily burn it.
Use of a fuel computer such as a VAFC to run the system ever so slightly lean at higher RPMs would unlock a bit more power, and would be ideal in climates where temperatures wouldn't get too cold (although you could always reset the VAFC to default in cooler weather). There's always a fear of burning something inside, which is why Honda set the fuel a little rich (that fear is accentuated in the higher revolutions).
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 04-11-2005, 03:39 AM
Janet Reno Janet Reno is offline
From what I know unless you actually get into VTEC the oil use is the same. I've heard of people who run in the twisties in the hills and are in VTEC for several minutes notice that it uses more oil than regular.
Old 04-11-2005, 09:09 PM
honda_racing101's Avatar
honda_racing101 honda_racing101 is offline
Send a message via AIM to honda_racing101 Send a message via MSN to honda_racing101 Send a message via Yahoo to honda_racing101
YAY! aces if finally back...been wonder where you were...Prelude forums have been kinda dead while you were gone
dSoc member #67
1995 Honda del Sol EG2 VTEC Milano Red. RIP :crook:
1994 Honda del Sol EG1 S-full VTEC conversion.
Buy my Del Sol parts!!
Old 04-12-2005, 12:43 AM
Prelewd's Avatar
Prelewd Prelewd is offline
Send a message via AIM to Prelewd
Anytime you run your engine in the higher RPMs, oil consumption is going to be higher..
Soon..
Cars:
1990 Nissan 300zx Twin Turbo
1992 Honda Prelude Si 4WS H22a Swap - For Sale
1965 Chevrolet 1/2 Ton - 500ci Cadillac Cometh
1970 Datsun 240z - For Sale
1972 Datsun 240z - For Sale
1977 Datsun 280z - For Sale
1991 Infiniti Q45 - Engine Donor to 240z - Parting out the Rest
Sold Cars:
1976 Jaguar XJ-S - Rear end Donor to Chev Pickup
1971 Datsun 240z
1984 Civic 1500 Hatch
