Old 03-31-2005, 04:02 PM
Scott82 Scott82 is offline
Got no spark
I double check my dizzy wiring and it seems to be right, i don't have time to work on it anymore tonight cause i have to go to work but i seem to be getting a little bit of oil into the dizzy cap, will this cause it not to spark? It turned over good sounded like it was in good time and plus i checked that before i put the motor in. I have a new dizzy, rotor button,ect. After i cranked it for about 2 or 3 min the dizzy caseing was fairly warm to the touch but nothing else on the motor was warm, it was hot enough for you to pull your hand off of it but it's not hot enough to burn you or anything. Anyone have any suggestions? i'll check back when i get off work tonight. Thanks Scott
Old 03-31-2005, 07:16 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Got no spark
switch the 2 white wires
Team Lonely Drivers
Old 03-31-2005, 09:15 PM
Re: Got no spark
i was hoping you wouldn't say that cause i have that harness wraped up already but i guess i have no choice. Thanks for the help man, I 'll see if i can't get it running tomorrow cause i am pooped out tonight and plus i need to get my beer drinking time in cause if i let my blood alcohol level get too low it might throw me off tomorrow. lol Again thanks for the help.
Old 04-01-2005, 02:09 AM
Hybrid1990crx's Avatar
Re: Got no spark
Oil in the dizzy? That could be a problem. The bearings inside could be going bad. I'd look more into that if I were you.
Old 04-01-2005, 08:25 AM
Re: Got no spark
Yea there are some seals around the shaft of the dizzy and stuff. I'll have to take the dizzy out to fix but i didn't think that a little bit of oil would cause no spark, cause it was just a little bit.
