Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-31-2005, 03:33 PM
Civic_D16Y5's Avatar
Civic_D16Y5 Civic_D16Y5 is offline
Send a message via AIM to Civic_D16Y5
91 octane map, switch to 116 map
friend is getting a auxiallry gas tank, and a switch, and another ecu with a 116 octane base map, while their normal fuel will be 91. when he wants he can flip a switch. what have you guys heard about this?
http://www.carsponsorships.com/scout/sponsor.php?id=737
GET SPONSORED, QUICK
Old 03-31-2005, 04:20 PM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
Re: 91 octane map, switch to 116 map
What kind of upgrades does he have? If he's got a really nasty set up then I guess it makes sense, but I don't think the higher octane really makes that much of a difference unless the car has an agressive set up (N/A or turbo).
Old 03-31-2005, 06:41 PM
12 psi, turbo
340 hp
ls
90 civic hatch
Old 03-31-2005, 06:57 PM
hmm, I guess it makes sense then. It certainly isn't going to do any bad. How much is it gonna cost to do the whole thing?
Old 03-31-2005, 07:14 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
you need to switch ecus everytime you switch fuel. also at 340whp he doesnt need 116, 91 can go till 400whp. also yeah it sounds like a good idea but what about the return line? is he gonna run a way to switch return lines to the aux tank ? if not then the 116 is going back to the stock tank and is gonna mix with his 91.
Team Lonely Drivers
Old 03-31-2005, 07:37 PM
yeah, the local import shop is gonna wire it all up for him and im sure thay will do something like that
Old 03-31-2005, 08:57 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
why use a different gas tank with a base map on 116? how about filling the tank up with 100+ and switching to a tuned map.................or am i just getting old?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 03-31-2005, 09:16 PM
turboEKhatch turboEKhatch is offline
Re: Re: 91 octane map, switch to 116 map
91 is good to a lot more than 400 WHP, I watched a local car here bust 465 to the ground on 91 octane before he called it quits, that's enough for me to see Everyone just goes ultra-conservative with tuning, which is why most people stop at 400-ish. A seperate tank is too many headaches to deal with. He will make more power than street tires can take on pump gas, why slap a second tank in there? If he REALLY wants to make more power on pump gas run a methanol kit instead of dicking with a second gas tank.
