Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 03-31-2005, 01:38 PM
Tony01 Tony01 is offline
Disk Brakes
Installing front pads. Compressing cylinders? Do I need a special tool to compress cylinder (as some cards need) or can I just compress them out?
Old 03-31-2005, 01:50 PM
IT Geek IT Geek is offline
Re: Disk Brakes
Nothing special with the front pads. You can use a big C clamp. However, I've heard (probably on this board), that it is best to crack your bleeders when compressing the piston. You let the old fluid bleed out instead of pushing it back up into the brake system. I guess the ABS system can be pretty picky when it comes to contamination, so it sounds like a good idea to me.
Old 04-07-2005, 04:31 AM
SteVB SteVB is offline
YES, definately open the bleeder screws to compress the piston. you don`t want to push dirty fluid back into the mastercylinder. just make sure to close the bleeder before releasing the c-clamp so you dont suck any air in the line..
