Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-31-2005, 01:22 PM
rekettyeit rekettyeit is offline
Eagle Crank Rods, Pistons
Hello!
I am thinking on this items:
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWA:IT
Anyone can give me information?
Regards
RT
Integra TypeR B18C6
Skunk2 Valve Train, Skunk2 Stage2
Old 03-31-2005, 01:31 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Eagle Crank Rods, Pistons
Well that crankshaft has a different stroke than your crankshaft, that is if you have a B18C6 which is the same as the B18C5 basically. Anyhoo if you do have the Type R motor than this crank is not for you unless you are looking to stroke the motor, but it will not be enough to warrant the cost. Also the crankshaft that is in the B18C5&6 are already balanced, it is the best crankshaft that came in the B series motors.
Old 03-31-2005, 01:44 PM
Re: Re: Eagle Crank Rods, Pistons
My crankshaft is ruined so i must to buy a new one
My crankshaft's stroke is 3,433"?
Old 03-31-2005, 01:59 PM
whtteg's Avatar
Your crank has a stroke of 3.19 in x 3.43 in and the crank in that link has a stroke of 3.19 in x 3.50 in also the rods are a little bit longer. That whole setup will work in yor motor but you need to realise that you will be lowering your R/S from 1.58 to 1.54. Not a huge deal but still that is extra wear and tear on your motor.
What happened to your crank in your motor?
Old 03-31-2005, 02:18 PM
Thanks for a lot, a have just find the correct crank on the site!
The bearings has been ruined.
The engine has 2liter oil finishd off in 500km, and has some noise, and halted.
Sorry for the writing errors, english is not my 1language
I am living in Europe, and here is very expensive all acura parts.
Very hard to buy from USA, many people don't send items to the overseas
Old 03-31-2005, 02:45 PM
Can you tell me what is R/S?
i am a lame...
Old 03-31-2005, 03:03 PM
Re: Re: Re: Eagle Crank Rods, Pistons
rod/stroke ratio...i got it
i am a lame...
Old 03-31-2005, 04:00 PM
turboEKhatch turboEKhatch is offline
Re: Re: Re: Re: Eagle Crank Rods, Pistons
If your motor needs a new crank that's a fine way to go, but are you sure it needs a new crankshaft? Probably just a spun bearing or worn rings or something. Have you torn the motor down yet?
Old 04-01-2005, 01:13 AM
Re: Re: Re: Re: Re: Eagle Crank Rods, Pistons
Yes and the spun bearing have eaten the crank
Old 04-01-2005, 06:55 AM
Kven's Avatar
Kven Kven is offline
that setup should work fine(in that link), i wouldnt worry too much about that low R/S ratio since theyve included new rods and rod bolts, which will help reinforce the bottom end(although, i would recommend resleeving or atleast a block guard/filling to help keep the cylinders from moving).
*btw, at the bottom it says the assembly is already balanced and ready for install.
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
