Stalls, P0336, tach stops working
Have a 2001 superchared grand prix. 3.8 L
I have taken it to several dealers and they can't seem to fix it. It throws a code P0336 which is crankshaft positon sensor. They swear that the sensor is fine, and thought it was the computer. The computer has just been replaced to try to solve this problem. The sympotoms are that it stalls at highway speeds, and sometimes the tachometer stops working. Charging system is good, just had a new battery installed. Any ideas? |
Re: Stalls, P0336, tach stops working
OK, I'm going to be the dumby today. The computer says it's the crankshaft positon sensor. The dealer says it's the computer. You change the computer and still have the same trouble? Why hasn't the crankshaft positon sensor been changed?
OK, that's my 2 cents for the day. Good luck.
Re: Re: Stalls, P0336, tach stops working
Not sure, but both of the dealers I took it to said that it can't be the CPS. If the CPS goes out of range, would the tach stop working?
Does the tach use the spark off the module, or does it use the CPS to determine the engine RPM's? |
Here is the basic theory of operation: The pulses sent from a crank or cam sensor generally are sent directly to an ignition module which transmits data to the ecm(computer). These pulses are generally a digital square wave pattern and can be easily read by most tachometers. A cam or crank sensor is generally located on top of or underneath the front or rear of the engine closest to that specific component(camshaft or crankshaft). Generally you would look for the crank sensor near the flywheel or the harmonic balancer at the front of the engine. Lastly, the ECM does not calculate timing order by itself. There is an identifier pulse sent by the crankshaft position sensor in the form of a longer pulse. Hope this clears things up. Good luck! |
Take it from me who has delt with the CPS situation. You change it and your problems will be solved.
could be a ignition control module also
sure but I doubt it. Mine threw the same code.
Called you Yesterday but you were working told your wife all the horrible things you say
Wife cleared caller ID. And I can't find your number. Couldn't call you back. Sorry.
