Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-31-2005, 11:33 AM
gen2gst95 gen2gst95 is offline
horrible knock
when my car starts to hit boost around 2500 rpm, I feel this sick ass knock. It's not just a little tap, as a boost leak would cause, it's a hard jolt. It does this until about 4500 rpms. It does this a lot more when my engine is cold, but its always there. I've also noticed that my car is ALOT slower than it was when I first bought it. It definitley shouldnt be doing this since I just got my car back last week from getting my head rebuilt. What could be causing this?
'95 Eclipse GS-T 5spd.---totaled..she was a bitch anyways
'06 Chevy Cobalt LS, Auto---sold to my sister. The most bland, numb-feeling car I've ever driven. Oddly torquey though.
Old 03-31-2005, 12:39 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: horrible knock
Stuttering and jerking isn't the same as knock. Knock will only reduce timing, and you will barely feel it if at all. You have an ignition problem most likely.
Old 04-03-2005, 01:30 PM
ignition, like plugwires? or like a whole new ignition
Old 04-03-2005, 05:20 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: horrible knock
Check all of that. Start with your spark plugs and make sure they are gapped correctly. Next check your plug wires and see if they are in good condition. Also check for arcing between the wires.
If all of that checks out and you're still having problems, check back and let us know.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 04-05-2005, 12:05 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: horrible knock
check the plugs before anything else.
95 Talon TSI AWD
97 Eclipse GST
Old 04-05-2005, 11:14 AM
my plug wires are shitty so it might be those, but I dont have the 40 or so bucks to get new OEM ones
It could be my plugs since the ones that are in there are platinum and I read that platinum plugs are bad for turbo cars. ALso, when I bought them ,I asked the guy at autozone how I should gap them, and he said they didnt have to be gapped at all, so I just put them in as is.
Old 04-05-2005, 11:26 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: horrible knock
Go get some NGK's and gap them to spec.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 04-05-2005, 04:07 PM
Re: horrible knock
the guy at autozone is an idiot and shouldn't be working there. always gap plugs before you put them in. the factory might have screwed up and who knows what kind of abuse those took on the ride from the factory to the store shelf. if you don't have money to buy new ones, sandblast the old ones or even do a quick clean job should make them last a little longer.
95 Talon TSI AWD
97 Eclipse GST
Old 04-05-2005, 07:44 PM
ill be able to scrape together the 12 bucks or so to get new plugs. Being broke SUCKS! ANother thing, I've noticed lately that I can smell unburnt gas inside my car, so I'm thinking bad fuel injector?
Sweet how I 've had my DSM since December and already spent almost 4 grand fixing the fucker and it still is messd up.
Old 04-05-2005, 08:17 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: horrible knock
the gas is probably from the misfire from the bad plugs/wires. get some ngk plugs gap them to .28 and slap em in there.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 04-06-2005, 11:16 AM
that would be sweet if it was just the plugs causing the problem. I'll buy some Ngk's after school today and post if my problems are fixed
