Go Back   Automotive Forums Car Chat > Saab > 900
Old 03-31-2005, 11:14 AM
sfguyer sfguyer is offline
97 Saab 900 Blower
My blower motor decides to work when it wants. i do not believe it's a bad motor. I have a new ACC Control Unit but no idea where it's located. I looked all over under the hood and with the dash all a part. I also just ordered a used ACC Comp. Mod. Any other ideas?
Old 03-31-2005, 08:41 PM
LlamaLadySG LlamaLadySG is offline
Re: 97 Saab 900 Blower
I don't have an answer, but you might check with the Saab 9-3 forum on your problem also. By 1997 the 900 was basically the same car as what is now the 9-3. Have you checked your fuse?
LlamaLadySG
Old 03-31-2005, 11:05 PM
Checked all the common items. Today it will work tomorrow it won't. I have noticed the various references to the 9-3. thanks
Old 06-06-2005, 12:49 AM
mbunakeith mbunakeith is offline
do you have acc or mcc? (sounds like you have acc). there is a blower fan speed controller on the right side of the heater box that may be the cause. if you have mcc (manual controls), check your fan speed controller under the hood cowl at the base of the windshield. they are prone to corroding.
Old 06-06-2005, 01:45 PM
It's ACC. What is the best way to get to it. I have looked but can't seem to find it which may be the problem....
Old 06-08-2005, 05:53 PM
if you take the right side center console cover off (one t25 screw in the glove box and one on the lower edge) pull the cover forward, this will disengage the clips on the rear edge( vertical part that radio and acc panel are in). take the glove box out and right side kick panel. the speed controller is located half way up the right side of the box(pass. side). it is a rectangular box about 1.5x1x1". if you wind up replacing it, make sure to smear some dielectric grease on the silver/metal part when you go back together with it. it may also be the fan motor also. i have come accross many cars that needed the fan and the speed controller. it seems the fan will wear out and it ruins the speedcontrol, or vice versa. you should be able to find these used. they are very expensive components when new.
