Old 03-31-2005, 10:49 AM
mprocino mprocino is offline
97 LeSabre Won't Start When Wet
The vehicle starts normally, except after there has been a heavy rain, (heavy enough where the rain splashes up from the pavement under the engine). I've replaced the starter, but the problem remains. Any ideas?
Old 03-31-2005, 02:26 PM
s426 s426 is offline
hi
are you getting any thing when you crank it, is there any light,are the sprk wire got any water, check also the batt cables. lift the hood open to let it dry out.
Old 11-29-2005, 10:45 AM
cardimwit cardimwit is offline
Re: 97 LeSabre Won't Start When Wet
Hi
I have the same prob. 97 le sabre won't start in high humidity - not necessarily heavy rain. I get a ticking sound from either behind/under glove compartment on turning the ignition key. No lights, nothing.
Problem solves itself if I let it sit a few hours. hence - by time I get it to the shop - they can't diagnosis the prob. HELP ME! I'm ready to get rid of the car. This has been ongoing for the past 4 yrs I'm fed up.
Old 11-29-2005, 01:04 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Hello
I had trouble with the ground by the battery that's mouted to the fender. If this ground is bad nothing works. Take off the nut, clean things up well and coat them with grease to keep them from coroding.
Dan
