Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 03-31-2005, 09:31 AM
johnsern johnsern is offline
95 Sub Horn Issue
My horn will just start beeping without any human help. It works if I push it. Could a cable be loose or wire short?
Old 04-02-2005, 05:22 PM
Eggert Eggert is offline
Re: 95 Sub Horn Issue
Hi,
please post your model / year.
Do you have the keyless entry? How does it beep, and how does that stop?
Take care, Eggert
Old 04-03-2005, 09:04 PM
1995 1500 v8. No keyless entry. "How does it beep" A steady on and off about 5 seconds in duration. I have folded paper stuffed in between the steering wheel and the airbag. This appeas to be working. Also, it happens at no constant pattern.
Old 04-03-2005, 11:12 PM
J-Ri's Avatar
J-Ri J-Ri is offline
There is a spring under the center cap on the steering wheel, just bend it out a bit.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 04-03-2005, 11:30 PM
Hi,
it is time to check the wiring, especially the steering wheel contact. Be aware of the airbag system. There is a whole bunch of things to do to protect the electronics and to keep the airbag from blowing up. This is not a casual do it yourself setup. I vote for the dealer to check this out because of the airbag system.
Take care, Eggert
