Old 03-31-2005, 08:09 AM
Sikman Sikman is offline
Brights light blinking
My dashboard bright light indicator is blinking and my day running lights are off. The headlights are fine otherwise, and the light quits blinking when I turn them on. I figure this is some sort of thing that should be obvious to someone who knows these cars. I never turned tham off(I heard you could), and checked the parking brake too.
Any thoughts?
96 GA GT.
Old 03-31-2005, 08:16 AM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: Brights light blinking
It sounds like it may be an issue with the BCM. It is a module located underneath the glovebox. It controls things related to the headlights, DRL's, ect. You may have corroded connectors or something on the BCM. It is common to have a leak in the firewall near it, and have the water cause problems with the BCM. It might not be a bad idea to pull your dash panels and check it out. Good luck.
Old 03-31-2005, 08:18 AM
Aww, man! You were supposed to say "It's a fuse.".
Just kidding. Thanks.
