Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 03-31-2005, 05:34 AM
scrap_iron scrap_iron is offline
22RE valvetrain
I have had my 94 p/u with a 22RE engine for about 6 months and it seems that the valve train is noisier than most other engines, but it seems to run fine. Is this typical for this engine design ? Do they have hydraulic or solid lifters ?
Old 03-31-2005, 04:47 PM
KimMG KimMG is offline
AF - Advisor
Re: 22RE valvetrain
Have you done any maintenance or repairs since you aquired your pick-up?
Old 03-31-2005, 08:19 PM
sassee's Avatar
sassee sassee is offline
Re: 22RE valvetrain
Rocker arms are actuated directly by the cam shaft. If your valve train is noisy, a valve adjustment probably is in order.
Old 04-01-2005, 04:08 AM
Re: Re: 22RE valvetrain
I changed the cap, rotor, regular oil changes at 4500 miles (it's almost all highway miles) using Mobil 1, Oil filter (Fram DG Doublegaurd series). I'll get to the plugs soon, and the Air filter looks clean.
Old 04-01-2005, 04:14 AM
OK - thanks, I'll plan on doing that soon. I picked up a Chilton book so I will read up on how to do it. I adjusted the valves on a solid lifter small block Chevy many years ago. It probably is a similar proceedure.
Old 04-01-2005, 12:56 PM
AF - Advisor
Re: 22RE valvetrain
Getting a manual is a good first step.
Now its time to do a bumper to bumper inspection.
This will help in developing a maintenance and repair schedule.
When adjusting the valves, do not reuse the valve cover gasket. If a valve cover gasket is compressed too much, the rockers will hit the valve cover and make noise. Use a little sealer on the half-moon shaped pieces (they're a common area for leaks). Don't overtighten when installing the valve cover.
