Go Back   Automotive Forums Car Chat > Daewoo > Lanos | Kalos
Old 03-31-2005, 04:41 AM
Scholarjack Scholarjack is offline
Question Lanos problem
I recently had a problem with lack of power in my 1999 1.4 lanos.I was advised that the problem was damaged valves.Since then I have had a new head and an injector assembly fitted.I have also fitted a new fuel pump assy plugs and timing belt.Still the problem persists. It appears as if not enough fuel is being delivered or the timing is off.Engine fires up fine but max achievable revs is 2000.This translates into 20-25 mph uphill.Engine does not sound right and there is little or no response from the accelerator.I'v spent quiet a bit of money listening to so called experts.
Perhaps someone knowledgeable about the vageries of the lanos might help.Thanks
Old 04-03-2005, 10:29 AM
carpy98 carpy98 is offline
Re: Lanos problem
have the timing checked. my lanos had similar responses but at higher rpm's. if not timing, sounds like engine- possible problems with the block/ pistons , since you have a new clyinder head ? i had a sunbird that lost power and the engine was euchered ! good luck
Old 04-07-2005, 02:04 AM
szefo szefo is offline
it is possible that the catalisator is broken into pieces and it stucks the exaust pipe unless I think it is obd II version
whatever it could be I think check light should be on
check egr valve although I think its inaappropiate working wont cause such less power,
maybe its something with coil
maybe its bad tps (throttle position sensor) but in these cases fumes should be blue, if they are not the only thing that comes into my mind is that there is something wrong with acceleration pedal but it is rather highly impossible
glad to hear any solutions that resolved the problem
Old 11-15-2005, 11:47 PM
tower621 tower621 is offline
Re: Lanos problem
I have a Daewoo,2001 Lanos. I need if any one has the Radio code.
