Hi everyone,
I've got a 2002 Jackaroo with 9000 miles it has engine surges when decelerating from high speeds, fuel has gone from 16-17 mlg to 13-14 mlg and is sluggish. Motor idles and runs smooth. I've done the egr, pvc perfect. replaced fuel pressure regulator and icv I'm out of ideas has anybody got any?? |
Re: AUSSIE jackaroo (trooper) needs help
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
re:img
hi there
thanks for the link i did consider the img but i counted it out because running smooth and cannot hear anyt air noise, no codes also. I will have to double check it and will let you know. thanks again. |
Does This Thing Not Have Any Kind Of Warranty On It Here In The States It 5 Yrs Or 60k And 100k Or 1o Yrs On Pwrtrain
Re: Re: AUSSIE jackaroo (trooper) needs help
Re: re:img
Hope that helps, Marc |
Re: Re: re:img
It got better when I had the IMG replaced. Honestly I never figured out what I was getting though.
Also, at the time I had the IMG's replaced I did the fuel and air filter, spark plugs, and cleaned the EGR and throtle body. So I did a lot of maintenance which helped. Also my tires were low on air pressure, all were about 8-10 PSI low. So I am getting better MPG now and all of this was done in early November. Did you change your fuel and air filter. I would think about changing them, but I suspect there may be a problem with the IMG's Marc |
I am glad to hear that there was no obvious signs on your IMG |
Re: Re: Re: AUSSIE jackaroo (trooper) needs help
Anyway on to your question. I have 73,000 miles on my Rodeo. The IMG went bad at about 69,000 miles or so, but many have had problems way before that. I am not sure it is your problem, but it is an issue with Isuzus of these years, so it is a good starting point. Good luck, Marc |
Aussie Ham. |
