Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-31-2005, 02:19 AM
Doughboy1993 Doughboy1993 is offline
Rotor--Recommendation
Hi Could anyone recommend good reasonable rotors for a 2001 Isuzu Rodeo Sport 4x4 3.2L which has disk brakes on front and back? I was looking at the drilled/slotted ones but the regular ones would be ok too. Anyone selling any? Thanks Brian
Old 03-31-2005, 07:39 AM
iskiuskiweski's Avatar
iskiuskiweski iskiuskiweski is offline
Send a message via Yahoo to iskiuskiweski
Re: Rotor--Recommendation
I got a quote from St Charles Isuzu for $98 each for the rotors, and $46 for the pads. Everyone on here recomends staying with the oem equipment, so that is what I am sticking with, great performance and very very long lasting.
98 Rodeo S/LS 3.2L V6 Auto 4WD 150k
Old 03-31-2005, 09:30 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Why? what's up with your current ones?
research these:
Powerstop cross-drilled rotors
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-31-2005, 12:08 PM
rodeo02 rodeo02 is offline
Are the factory rotors shot already? Factory rotors typically last a LONG time on rodeos. Like 100Kmi+, and can handle being turned. If you need to replace them, I wouldn't necessarily go OEM for rotors, but price NAPA & carquest first. If they are the same $$ as OEM, then go OEM thru St.Charles or the likes. Keep in mind that you will have to do a full front wheel bearing service on your 2001, as you will have to pull the hubs apart to remove the front rotors.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 03-31-2005, 08:12 PM
Re: Re: Rotor--Recommendation
Thanks for the Info....
Old 03-31-2005, 08:33 PM
research these:
I just purchased my Rodeo Sport and checked the brakes and found out that they were pretty bad and never checked or changed before. The brakes were basicly gone and they chewed up the rotors. The one set of rear brakes were totally missing.
Old 03-31-2005, 08:38 PM
G/luck
Joel
Thanks Joel for the information... My Rodeo Sport only has about 44,000 miles on it but the previous owner never checked or changed the brakes before and left them grind to nothing and chewed up the rotors pretty bad.
Old 04-02-2005, 01:19 PM
ibew595's Avatar
ibew595 ibew595 is offline
Send a message via AIM to ibew595
I'm happy with the OEM Rotors and pads. I have 133k miles + on them and still have pad left and the rotors have no grooving or have worn down.
94 LS 3.2
email"A.F."in subject line only
Mt. Hamilton 9/03
Kevin Goto
2000 740 i
Impala Brown
Annalisa
Old 04-02-2005, 10:58 PM
94 LS 3.2
Thank you for your help....
